[image: View Post]CandyRedRC46, on Oct 15 2009, 11:31 AM, said:
[image: View Post]dogman, on Oct 14 2009, 08:27 PM, said:
[image: View Post]Auspa�ol, on Oct 15 2009, 04:19 AM, said:
Let's see if I can add something to the debate... the following is very "long-winded" so please take a long breath (pardon the puns)...
I have done the VTR1000 fan swap on a 5th gen. I have another VTR fan for my 6th gen, yet to be installed, I'm still contemplating it's efficiency/usefulness.
You don't actually swap the whole fan (as in motor), just the plastic blades. It is a direct swap, no mods needed on the 5th gen (nor on the 6th gen). Turning the OEM fan upsidedown will do nothing but render it less effective and reversing the direction it spins in will reverse the airflow but, once again, it will be much less efficient (for two reasons: the angle of the blades are designed for optimum performance in one direction, AND one of Newton's laws of physics, see below**).
The VTR fan is ONLY better depending on the types of situations your bike usually finds itself in.
To those who say Honda has installed the "perfect" set-up on the VFR and we should leave well enough alone, I'm not so sure. Why then does the VTR blow air from the inside out and the VFR suck air from the outside in? They are basically both the same configuration in terms of side mounted radiators with a fan only on the one side. Which one is more effecient? I believe Honda has done so rationalizing that the end-user of a VTR will use their bike in different conditions/ways to the VFR rider. Sport vs. Sport-touring.
A thing to keep in mind is that the VTR fan's motor is more powerful than the VFR's... not by much but I mention it to address a point I make further along (**). Newton's law is the reason why.
I agree with Candyred on the most part. You're basically swapping advantages in certain case-scenarios for disadvantages in other case-scenarios.
It is true that at certain speeds, the airflow being drawn in by the OEM fan is rendered null and void by the air rushing in due to the forward movement of the bike. This is what inspired me to try the VTR swap over, as I use the bike everyday for commuting to work and often find myself at low to medium speeds whereby the fan is not capable of lowering the (refigerant) temperature because its flow is hampered by the bike's forward movement.
BUT, I discovered that, as of a certain ambient temperature and/or humidity, coupled with the fact that due to some supposed law of physics, (**) (it appears that drawing air through a radiator requires less effort than blowing/pushing it through), with the motorcycle stationary (for example at a long-lasting red traffic light, and some over here encourage one to take a novel to read in your tank bag), during the hotter times of the year (>30�C) it is more than obvious (my observations and experiments) that with the VTR fan, after a couple of cycles of temp increasing, fan coming on, temp dropping, fan switching off, temp rising, ad libitum..., let's say twice MAX (in hot weather)... the VTR fan is finally incapable of lowering the temp to below the cut off point... and eventually the temp just stays constant and finally starts rising (ever so slowly)... even if not completely stopped, if you spend long enough in slow traffic on a hot day, this will be the final outcome.
The OEM VFR fan is much more efficient when there are no antagonistic influences involved (like the incoming air from the forward movement of the bike). It is not altogether 100% efficient though, and will eventually end up in the same dilemna whereby it is incapable of lowering the coolant temp... but it takes quite a few cycles more to get to this point and it will depend on whether you spend more time stopped than going slow.
Once in motion, the VTR fan does its job way more efficiently than the VFR one, as the airflow it produces complements the incoming air due to the forward movement of the bike. But we must consider whether or not the extra load the VTR fan-blades place on the VFR fan's motor (**) is worth it or not and whether or not the type of riding/traffic conditions we tend to encounter justify this extra load and find the system benefitting more than not so.
The VFR is a hot running bike. I find with everything stock, if I'm not doing at least 70-80 km/h the coolant temp will rise to the point where the cooling system enters into that vicious cycle of thermoswitch turning the fan on, and if you're lucky/according to the conditions (speed, amb. temp., atmospheric pressure), dropping and rising and dropping, and if you're unlucky (once again according to speed, amb. temp., atmospheric pressure), it won't even drop. Of course, all the time the fan is fighting against the incoming natural airflow, the VFR's (rather delicate) electrical system is under unnecessary load.
I feel the solution in the end is a combination of things. Tightwad and I have chewed the cud on this one a bit... he has much fancier ideas than I, being a bit of a sparky... I'm just a layman.
The VTR fan is better for when we are in motion. (Due to lack of the antagonistic factors such as those existent between the VFR fan and natural airflow)
The VFR fan is better when we are stopped. (Due to a law of physics that states it's easier to pull a load (through a radiator) than to push it)**
We could hook up a simple manual switch to turn the OEM VFR fan OFF when at speeds that render the fan's efforts useless (we would have to judge when to turn it off and/or back on). Tightwad goes beyond that to switches with programmable time periods in which after a time the circuit is closed again automatically, using nifty little circuitry bits, too complicated for me, in case the rider forgets to turn the switch back to stock set-up mode.
If we install the VTR fan-blades, we won't need the switch, but what do we do when stopped a lot in traffic?? As it will overheat sooner and worse so.
The VTR blades would be the perfect swap for track use.
A bigger/more efficient oil cooler would be an obvious helping hand.
Some sort of fan on the RHS radiator would come in handy, but there's very little room on the inside there and you couldn't have two fan motors like the one on the LHS radiator running at the same time, too much load. I have seen two PC fans (like the ones you guys hook up to your R/Rs on the 5th gen) placed on the outside of the RHS radiator in the gap between the rad and the fairing. At least one of these and half the other is comletely visible (= anti-aesthetic). But these fans create very little airflow (relative to requirements), although, being on the outside and orientated in such a way that they draw air from within the engine bay to the outside , they would be more effective than if they were on the inside pushing the air outward through the rad (due to Newton's push-me pull-you law**) (...as if there were room for them in there... well there is room for 1 8x8cm PC fan on the inside lower frontward corner of the RHS rad).
Instead of installing a thermoswitch (not thermostat which is a different thing) with a lower engagement/disengagement temperature range, we could install a three way switch that not only allows us to turn the fan OFF as per the previously described scenario, but also allows us to turn the fan ON when we think it would be of benefit... (the third position is obviously to leave it in stock set-up).
Or we could just say to hell with it and move to colder climates.
In as much as the Japanese girl's (I assume police) VFR... I think the original author is referring to the esky installed in the pillion space for enjoying a nice cold-one whenever you need cooling off!!
There are more variations on the theme but I'm starting to get dizzy (cold-ones don't help here)... ah BTW, I don't see how cross currents to the RHS radiator could really be something to take into account... and if they do exist, they would only do so when stationary, so you're in the same boat, right? (The one that's up shit's creek without a paddle, basically).
Please do excuse the rant. I hope it is useful to someone.
The part number for the VTR fan is: 19020-MBB-003 in case someone feels their use of the bike would benefit.
Yours truly,
Auspa�ol
(Ol� mis huevos :cool: )
PS: Now you can breathe
I agree with everything you say.
I have done the VTR fan swap, and fitted a manual override switch, and what i do is if I get into a situation where the temperature starts to rise above 90deg C (195degF), I just simply turn the fan on and leave it on until the situation changes.
Having said that, I find that my 07 model runs very cool anyway, unlike my prevoius 02 model and 99 model which used to cook on a hot day, but I dont commute on this bike, and am rarely stuck in traffic.
I used to have a VTR1000, and I thought their setup was much better, thats why I did the swap.
I'm not sure why the 07 is cooler, (have honda increased the capaciy of the radiators? it holds 3.1 litres now?) but I have a PC3 and it is richer than standard at low revs.
I think the lean running of the factory ECU setting is a big part of the reason they run hot.
If I am touring on say an 18degC day, my engine never gets hotter than 76degC (169degF), and yes the thermostat is OK.
One of the things I hate about the standard setup when you are stuck in traffic on a hot day is the way the heat from the fan wafts up through the headstock just to complete the sauna effect.
I traded my 5th gen bike partly because of this, but I wasnt aware of fan swaps etc at the time. I used to regularly see 117deg C (243degF) on the temp gauge.
Just my 2c
you should look into the different fan switches available. i have one out of a 82 nissan pulsar. it turns the fan on around 197*
and then it shuts the fan off at around 182*.
Yeah, I might check that out, thanks
