At the end of October, I made an offer on a Silver 2003 VFR 800 being sold on consignment at a local Suzuki/Yamaha/Kawasaki dealership. As soon as I got into the parking lot, the salesman called me back in and told me the owner accepted the offer!
It needed some work, so I took a few pictures along the way.
First day - 18,400 miles
The chain and sprockets were toast, as were the tires. Rode it home very very gently and put her in the garage and started ordering parts. Micron slip on exhaust sounded nice, though! But the previous owner had them flipped -- left can on right side and vice versa. Not a priority though, no leaks.
FIRST THINGS FIRST
The stickers have GOT to go!
That's better :)
Then it was time to get the plastic off.
Not surprisingly, the plastic rivets on the bottom were missing. And several just broke when I tried getting them out. So I stopped by the Honda dealer, and they wanted FIVE DOLLARS EACH for those. Outrageous. Ordered a bag of 25 plastic rivets from thefastenerwarehouse.com (part TR 240). Haven't tried them yet but they look like they ought to be a great replacement.
Oil looked to be pretty dark, but not too bad. Hard to tell without actually sending it out for analysis though. Filter wasn't on too bad - an extension and cap wrench were a huge help here. Replaced with Amsoil 10w-40 and Purolator oil filter from the Pep Boys.
Now on to the air filter. First off, being able to just tilt the tank back and prop it up is SO nice on this bike. Makes it very easy!!
That filter was NASTY. Cleaned it all out as best I could and put it back - a K&N is on the to-do list but not a priority at the moment.
sprocketcenter.com was very helpful on the phone, and shipped out quickly.
Another member pjm204 helping me change the sprockets and chain. Went with a DID 530 I think, and stock sized sprockets. Used the RK Chain breaker/riveter tool. Fairly easy to use!
Then the antifreeze, brake fluid, and hydraulic clutch fluid needed to be changed out:
Coolant looked pretty clean, but flushed with 2 gallons of distilled water anyway. Filled with Prestone Green 50/50. Cylinder drain bolt wasn't too easy to get to, but a short ratchet makes it a pretty easy job.
Brake and clutch fluids weren't too bad, but a little dark. Just took a while with the linked brakes.
Time for tires!
Let me just say, center stands combined with single sided swingarm = easiest wheel removal ever!
Put a scissor jack and wood under the headers to get the front wheel just barely off the ground so I could remove it. Put ratchet downs on the ceiling to the rear passenger pegs JUST in case, but it wasn't going anywhere.
Went with Shinko 005's.
Windscreen also needs to be replaced. Thinking about trying to sand it down and hit it with Nightshades spray paint. Can't be worse than it is now!
Getting along with her new garage mate, my 2007 Honda VTX 1300c
Next up:
EBC Brake pads already ordered, as well as passenger seat cowl and those grab handle cover pieces.
I'll post up more pics once that gets done.
Thanks to all for the information and answers to my questions this far. You've been a great help!
FIRST THINGS FIRST
That's better :)
Time for tires!
Next up:
