What's This?
30 posts Started 5 Nov 2009 Last recovered post 30 Nov 2009 Wayback Machine snapshot 12 Apr 2010
Behind the round part of the light lins shown here, is a hole about 2" behind the lins. I couldn't find any info on the purpose of it.... Does anyone Know what it is?
Attached thumbnail(s)
  • [image: Attached Image]
thought it was a parking light for Euro-spec bikes. someone else will have to confirm.
Yeah, it's come up before.
Other countries require running or park lights and on Euro models you will find lights installed in these locations! :rolleyes:
Well... That was to easy :fing02: ...Thx
Nice. Now we just need someone to put lights across from one running light to the other. Make 'em go back and forth and you'd have KITT on two wheels. ;p
Or alternating Red/Blue!
Can't wait to see what you're going to put in there, Monk!
Actually, I like the KITT concept, but I have such a dislike to messing with MC electrics I'm sure I'll leave it alone(although I do have it wired for volts/vest/charger). :beer:
the latest farkle is hatched................
you will need two of these............
http://i113.photobucket.com/albums/n206/Dutchy_748/HPIM5274.jpg
http://i113.photobucket.com/albums/n206/Dutchy_748/HPIM5275.jpg
http://i113.photobucket.com/albums/n206/Dutchy_748/HPIM5273.jpg
:cool:
:cool:
Ooooo, gotta part number by chance?
:cool:
..and why were you photgraphing parts on yer roof?!!???
I think they're called "City light". A sort of marker light that turns on with your park lights.
It's just one of those goodies that they give most of the world and leave off on US bikes and cars.
Maybe we really can't blame the manufacturer for leaving those out as the DOT guidlines are so strict on what you can and could not have on your vehicles. The bike and car companies might have decided to leave things off that are not in the DOT requirements list to avoid having to take them all out later as a recall if some engineer/beureaucrat at DOT suddenly decides it's not a "safe" thing to have later on.
Beck
95 VFR
:cool:
Cuz in The Neverlands, all you have to do is walk off the road and you're on the roof! :goofy:
Red and Blue???? :warranty:
http://superlumination.com/images/auto_bulbs/194i_rb_wm.jpghttp://superlumination.com/images/auto_bulbs/194_5led_rb_wm.jpg
Or how about 'Purple Haze'??
http://superlumination.com/images/auto_bulbs/ba9s_wp_wm.gif
Wow, Monk, I was wondering the same thing. I'm glad you were able to take a better picture of it that I was! (And that you went ahead and asked.)
Now, fellas, how 'bout those part numbers? :biggrin:
Any luck with part numbers? Or at least numbers for the sockets at each end?
Thanks, all.
Thanks, all.
will drop by the dealer on saturday....
I want to figure out how to install a radar detector in that spot so it's hidden.
I don't think hiding one will do any good, at least in Va. they can tell if you're running one. Also it's has more range the higher you mount it.... Just a FYI.....
Yup. Virginia will pinch ya for using one. (Darnit.)
Back on track... I found this page this morning: http://www.bike-part...8-F__0100-.html
The diagram number (FWIW) is MCWE-F0100, and applies to the 2008 model. (I couldn't find a 2007 model listing on that site.)
The pigtail is known as "Socket comp." and is item 6 on the diagram. I don't have a part number yet, though. It appears I have to register on the site in order to get part numbers.
Here's the diagram, though:
Image: http://www.bike-parts.fr/h/motog/13MCW601/IMGE/thumb580280_F__0100.png
More surfing to do...
Hey, are we at all optimistic that our bikes have connectors already hanging there, into which to plug this connector?
I'm guessing... but I'd say it should fit any 6gen .... and I'm not to optimistic they're going to be there disconnected....
I figured they'd be relatively "6th Gen generic," but I do worry that I might take the time to open things up and then find nothing there to connect to. What a bummer that would be!
Well Veefer Madness managed to hook his's up..... but he is Canadian and I donot know how they differ from US spec..... :biggrin:
I'm not interested in hiding it for police purpose. I live in South Carolina and rarely if ever travel to Virginia. I just don't want to have my radar detector mounted out where I can see it. I just want to have a discreet alert device and not actually have the bulky device there. Another reason is I want to permanentally affix it on the bike, waterproofed and all. It seems like a good place to put the detection device.
[image: View Post]Dutchy, on 27 November 2009 - 10:31 AM, said:
Well Veefer Madness managed to hook his up..... but he is Canadian and I do not know how they differ from US spec..... :biggrin:
I spent a couple of minutes in the garage this morning, looking around the nose of the VFR. I came back with two observations. First, I don't see any loose connectors in there that look like they'd attach to the harness Veefer Madness showed. :unsure: Second, and perhaps more disturbingly, I felt in behind the round space where that bulb/socket would sit. It doesn't feel like something that will push/pull/pop out. Does this mean there's some serious disassembly and then some cutting involved? :blink:
Honda part # is 33140MCWD001
costs Eur 10 here, so around $15
You're the man, Dutchy! Thank you for fishing out the part number.
Now if I can find what it connects to, and how to install it, I'm set. :)
The plugin on that looks to be about the same as whats used for the air temp sensor.
Having had the "pleasure" of tearing the front off, I don't believe my '02 has any spare wires up there. And the headlight buckets would have to be drilled as there's no knockout or hole there.
One thing to remember, you can't have any light other then white or amber showing forward here in the US.
Now, if you rig a switch to use only when parked, you're fine.
1)No plugs on the harness for this
2)You have to drill the hole out on North American headlights
3)Splice into any switched green and also a brown wire up front.(headlight low beam or running light up to '05. '06 and up, lic. plate light or low beam.
4)Either splice direct to light socket to bike harness or get corresponding plug for disconnect setup.
Blue led
Amber
Plug socket
Plug Connector
Greg :fing02:
End of thread · 30 posts recovered Wayback Machine snapshot 12 Apr 2010
