[image: View Post]Pete McCrary, on 26 January 2010 - 09:58 PM, said:
[image: View Post]jpdesigns, on 26 January 2010 - 10:37 PM, said:
This is probably a dumb question, but I don't have a manual. Is there a prop for the fuel tank somewhere? I have an 02 and just got it this past fall. It's possible mine is just missing. If so, are there any good ideas for a replacement (all thread, coat hanger)?
Jimmy
It's that rod under the seat that you have no idea why it's there. Remove the two bolts at the front of the tank immediately behind the steering stem. One end of the rod goes into one of the bolt holes in the frame, the other end goes into the collars inside the grommets in the tank. The rear of the tank is hinged. You can only lift the front of the tank about 10-12" before hoses and wires start pulling tight.
Warning, those collars inside the rubber grommets in the tank will fall out very easy and fall down into the innards of the bike to be all but impossible to get out or find again. If you do unbolt the front of your tank, put a dab of 3M Trim Cement on the collars so they don't fall out of the grommets the next time you have the tank up.
If your prop is missing all together, go to Home Depot and get a section of one eighth inch steel rod and cut it to length and bend as necessary.
Huh :comp13: mine never came with a rod for the tank!
I typically use my rubber mallet, striking end on the airbox, handle on the tank...when I did my valve adjustment I used a piece of rope, got it the right length and voila :fing02:
The rod is a good idea for the garage, but the rope is a lot lighter and easier to carry on the road perhaps :wheel:
http://www.vfrdiscussion.com/forum/uploads/1231761920/gallery_14545_4382_465741.jpg
the valve adjustment! not too bad
