Brake pads choice? Who uses what? Reviews
[image: View Post]PACIFICMAN, on 26 February 2010 - 05:08 PM, said:
I am about to do my brakes, 2002 VFR, I am looking at the obvious, EBC and Galfer. What have others used and liked? Other brands?I only use Honda brake pads.They are more than adequate for street use,they last,and after 60000 km. my discs still look like new.I checked them with a micrometer and wear was minimal.
[image: View Post]timmythecop, on 26 February 2010 - 11:54 AM, said:
EBC HH. Nothing beats them.Yep, what he said!
[image: View Post]timmythecop, on 26 February 2010 - 12:54 PM, said:
EBC HH. Nothing beats them.^^^^ http://www.vfrdiscussion.com/forum/public/style_emoticons/default/+1.gif ^^^^
Beck
95 VFR
Given the choice, I probably would've given the EBC's a shot.
x3
x3
x4
Great pads, If properly bled you can get the same performance as OEM "Using 1 finger on the lever"
x3
x4
x5
Very good pads, wet or dry
x3
x4
x5
Are you guys running HH front and back? Or just up front?
[image: View Post]Hoyle2001, on 26 February 2010 - 10:57 PM, said:
Front and BackX2. Never really thought of not running the same pads, nor would I ever. Then again, I have never mixed tires as well.
FYI EBC are cheaper than OEM
I'm coming from a Katana forum and it doesn't have linked brakes. The general train of thought was since the HH are grabbier it was better to run them up front, and run stock pads in the rear so as not to increase the chance of locking the rear wheel under hard braking.
[image: View Post]woobie, on 26 February 2010 - 10:51 PM, said:
Are you guys running HH front and back? Or just up front?I only use my rear brake for sitting still on a hill.
I mean dif. code and dif PRICE .
06456-MCC-006 , Front R
06455-MCC-006 , Front L
FR is 3$ more than the FL .
VFR 800 Vtech is the ONLY Honda moto that uses Dif pads for the front wheel . This is because the Front caliper are different ( the right middle piston is smaler than the left middle piston )
As far as I Know ebc,ferodo,brembo sel the SAME pad for FR and FL .
[image: View Post]lazkal, on 27 February 2010 - 01:28 PM, said:
Front OEM ONLY , because the F.Right and F.Left pads are DIFFERENT .!!!!I mean dif. code and dif PRICE .
I installed the same pads front and rear and have not had any issues.
Not sure if you're right on the pads being different.
May wana doublecheck that.
x3
x4
x5
X 6
I have never used anything better... :fing02:
[image: View Post]PACIFICMAN, on 27 February 2010 - 09:04 PM, said:
I spoke with the dealer regarding this subject. Apparently the right and left factory pads are different (heat pads, spring plates, spacers, etc...), however, the "architecture" of all the calipers is the same. This allows aftermarket suppliers to use the same application all around the bike.The front calipers ARE different .
Aftermarket suppliers sell the same pads to CBR 1100 XX and to VFR 800 Vtech .
1100 XX
Front Left :06455-MAT-E21
Front Right:06455-MAT-E21 . The same .
800 Vt
Front Left : 06455-MCC-006 . The same as 1100 XX
Front Right: 06456-MCC-006 .Different !!!
I believe that there is a reason for this extra code .
[image: View Post]PACIFICMAN, on 27 February 2010 - 02:26 PM, said:
Hey All, Secondary question, Do you all change the pins as called for? Or is that bunk? How about the O ring on the end? Mine seemed fine when I took them out. I assume Honda calls for the R&R because they are such soft metal. Any thoughts?My guess is "liability." I have always reused mine on every motorcycle Ive ever owned as they all have been in great condition.
Flash
I use Permatex synthetic brake grease on them.
http://ecx.images-amazon.com/images/I/51RASG8WZ2L._SL500_AA280_.jpg
http://www.permatex....otive/20353.pdf
x3
x4
x5
X 6
X 7 :fing02:
[image: View Post]enzed_viffer, on 27 February 2010 - 07:34 AM, said:
Not that it matters, because you prolly caint get'm in Mrka, but up until the last pad change, I always used SBS, because that's what my 'bike guy' stocked. However, he quit his business, and the bike shop I went to fitted Ferodo without asking me what I thought. I must say, they worked very well once bedded in, and cleaned up the surface of the disks very nicely, so they must be more abrasive than the SBS pads were. The disk surface looks very even and flat now. :fing02:Given the choice, I probably would've given the EBC's a shot.
Blargh! I had Ferodo pads once, and they sucked on my '02! Terrible feel at the lever and no bite at all. I'm much more comfortable with the SBS pads, and really can't complain about them.
Flash
x3
x4
x5
X 6
X 7 :fing02:
X8
Put them on last year. They do me just fine.
The OEM uses a specialized compositry pad differnce on front calipers, atleast for the abs models
Honestly, I didn't notice a dramatic difference between OEM and the EBC HH pads.
The EBC require more warm up and have created an annoying little squeak just before stopping.
I'm going to switch back to the OEM ones next set (probably by the end of the year) so we'll see if I'm missing something.
[image: View Post]jfviffer, on 27 February 2010 - 05:51 AM, said:
i guess im the odd one out wont use EBC HH again. much better in dry conditions.OEM are better in wet conditions by quite a bit.FYI EBC are cheaper than OEM
I do use that engine brake a lot though..... :fing02:
Using OEM Honda parts, they worked fine the first 55,000km so why not stick with them. $100 for all 3 sets from my local dealer. Each set is a diffrent part number so make sure you only do one at a time. :warranty:
