Windshield Turbulence on 2 Gen - Aftermarket Solutions?
3 posts Started 23 Jun 2010 Last recovered post 23 Jun 2010 Wayback Machine snapshot 4 Jun 2011
Picked me up an 87VFR700 last summer as my 1st street bike, she's been a great bike so far, but I have a couple complaints.
1. Front suspension seem a bit soft. I feel as if I've bottomed them out a couple times. Are they nitrogen-filled shocks only or can I pump them up with air? Also, where does one find a pressure gage that reads 0-10 psi accurately?
2. Wind noise. It has the stock smoked windscreen ( I think), and the wind is hitting me just below the visor. If I lift my head above the windstream into the unaffected air, it becomes much quieter.
I've debated cutting down the stock screen, but I'm thinking the turbulence will be too great at highway speeds (75-85mph) with no wind protection. I have a HJC helmet, nothing fancy, but she's comfortable and I'm saving for a good pair of protective riding pants, jeans make me feel unprotected. I can tuck behind my windscreen at speed. but the noise from the bike matches the roar from the wind, so no go on that one.
So what's the deal? I've looked up the main windscreen manufacturers and no one seems to make them for a bike as old as mine. I'm not that tall, 5'10", but I have a longer torso so I'd say it's equivalent to a 6 footer. I would like something that looks stylish, but not too expensive. I'm perfectly willing to drill and cut the screen, but I do not want to damage the stock plastics in any way.
Thanks fellas.
Attached thumbnail(s)
  • [image: Attached Image: vfr outside.jpg]
I own a 93' and have the same problem with wind noise that you have. I have tried everything you have mentioned with only minimal results. I am about 5'8" and the windstream hits me at about the chin of the helmet. I started with trying to cut down the stock windscreen, actually took it lower than the mirror mounts, didn't help. I have found that a majority of the wind blast is affected and directed most by the angle of the headlight, which makes sense because that is what it hits first. I tried a Givi touring screen that is 2 inches taller than stock and kicked up at the top, works for keeping you warmer in the cold months, but not with buffeting and noise. I even have some of this Micro-swirl edging on the Givi like in the picture and it didn't do much of anything for me. The only thing that has helped at all is this Windjammer and earplugs. I have been thinking of having the seat recovered and adding an inch of foam to get me up a little higher in the clean air but I am weary of not being able to touch good enough during a stop.
End of thread · 3 posts recovered Wayback Machine snapshot 4 Jun 2011
