Thanks.
Thanks.
[image: View Post]SEBSPEED, on 29 June 2010 - 06:34 PM, said:
You can try removing 10mm of oil height first, 5mm at a time. That will soften it up a bit, not sure if it will be enough though.[image: View Post]BaileyRock, on 29 June 2010 - 07:52 PM, said:
First off how much do you weigh?[image: View Post]jaimev34, on 29 June 2010 - 09:16 PM, said:
[image: View Post]JamieDaugherty, on 30 June 2010 - 04:12 PM, said:
As I recall, I set your shock up softer than I would prefer (normally I would suggest something higher than the 1050lb/in). Based on that I'd say you seem to like a softer spring setup. Using that logic a set of 0.85kg/mm forks springs should be ok. As for the valving, you are probably ok leaving it alone. Ideally you would make a correction for the change in spring rate but I don't think you would have any troubles leaving it as-is.[image: View Post]jaimev34, on 30 June 2010 - 07:27 PM, said:
As I recall, I set your shock up softer than I would prefer (normally I would suggest something higher than the 1050lb/in). Based on that I'd say you seem to like a softer spring setup. Using that logic a set of 0.85kg/mm forks springs should be ok. As for the valving, you are probably ok leaving it alone. Ideally you would make a correction for the change in spring rate but I don't think you would have any troubles leaving it as-is.[image: View Post]BaileyRock, on 01 July 2010 - 08:19 AM, said:
As I recall, I set your shock up softer than I would prefer (normally I would suggest something higher than the 1050lb/in). Based on that I'd say you seem to like a softer spring setup. Using that logic a set of 0.85kg/mm forks springs should be ok. As for the valving, you are probably ok leaving it alone. Ideally you would make a correction for the change in spring rate but I don't think you would have any troubles leaving it as-is.[image: View Post]jaimev34, on 01 July 2010 - 08:24 AM, said:
As I recall, I set your shock up softer than I would prefer (normally I would suggest something higher than the 1050lb/in). Based on that I'd say you seem to like a softer spring setup. Using that logic a set of 0.85kg/mm forks springs should be ok. As for the valving, you are probably ok leaving it alone. Ideally you would make a correction for the change in spring rate but I don't think you would have any troubles leaving it as-is.[image: View Post]mello dude, on 03 July 2010 - 10:08 PM, said:
Arent the stocker springs ---- .79?[image: View Post]Auspa�ol, on 04 July 2010 - 08:27 AM, said:
Are your new springs progressive or otherwise?? 20 mm free and 32 mm w rider on is a little odd doncha'all think??[image: View Post]jaimev34, on 04 July 2010 - 11:47 AM, said:
I was pondering yesterday that free sag is an odd concept. Think about this: Let's suppose you've got a guy like Brock Lesnar, who walks around at somewhere near 390 lbs. He would probably need some really stiff springs on the VFR. Let's assume they're around 2.0 kg/mm, or whatever the measurement is. How much free sag, if any, will he be able to get out of those springs? Yet those are the springs necessary for the bike to be able to carry his big ass. I doubt the bike would even make the suspension budge on its own. It seems like the stiffer the spring, the lower the free sag, especially at the higher end of the spectrum. So, how important is free sag if there it becomes nonexistant with certain riders?[image: View Post]JamieDaugherty, on 04 July 2010 - 12:02 PM, said:
I was pondering yesterday that free sag is an odd concept. Think about this: Let's suppose you've got a guy like Brock Lesnar, who walks around at somewhere near 390 lbs. He would probably need some really stiff springs on the VFR. Let's assume they're around 2.0 kg/mm, or whatever the measurement is. How much free sag, if any, will he be able to get out of those springs? Yet those are the springs necessary for the bike to be able to carry his big ass. I doubt the bike would even make the suspension budge on its own. It seems like the stiffer the spring, the lower the free sag, especially at the higher end of the spectrum. So, how important is free sag if there it becomes nonexistant with certain riders?[image: View Post]jaimev34, on 04 July 2010 - 12:16 PM, said:
What do you think about a max rider sag of 32mm on a VFR, without any preload?[image: View Post]jaimev34, on 04 July 2010 - 12:16 PM, said:
What do you think about a max rider sag of 32mm on a VFR, without any preload?[image: View Post]Auspa�ol, on 04 July 2010 - 01:13 PM, said:
Maybe a little stiff if you prefer a plusher ride, but it's perfectly within the typical 30-40 mm range (based on the common theory that sag should be 1/4 - 1/3 the fork travel, and fork travel on the VFR = 120 mm).[image: View Post]jaimev34, on 04 July 2010 - 06:11 PM, said:
However, since I'm not using 100% of my travel, I'm thinking I may cut the spacers a few mm. I have about half an inch of travel that is unused, as measured by a zip tie.[image: View Post]JamieDaugherty, on 05 July 2010 - 10:08 AM, said:
