Dead LCD? - Fifth Generation VFR's
8 posts Started 4 Jul 2010 Last recovered post 10 May 2012 Wayback Machine snapshot 24 May 2012
The LCD just went blank.  It was working on my last ride, AFAIK.
I have power to the fuse, but that is as far as I got.  Need time to get the front cowl off to learn more.
Anybody have this happen?  Its been dead for about a week.  No fuel guage :laughing6-hehe:
Ian
Anybody have this happen?  Its been dead for about a week.  No fuel guage :goofy:
Ian
Same thing happened to me an hour ago. :/  Did a search but didn't come up with anything.  Weird.
It may not be the same, but when I purchased my salvage 5th gen (it had been underwater in a basement for 5 days during the Boston floods a few years ago) The LCD was not working either.
I purchased a new LCD from Honda (I needed to show parts receipts to show how I had "rebuilt" the salvage bike to get it registered) and during the trouble shooting phase I found a broken wire on the printed circuit that backs the panel.
I soldered a power wire aroung the break and have been running the bike as suck for 4 years and 30k miles now.
Great, thanks guys.  I'll tear into it this week and let you know what I find.
I read on some other forums and found only a few threads... somebody indicated that due to exposure to water, some of the traces on the back of the LCD PCB had become corroded and after cleaning the back of it using some cleaning product, everything was good.   Or something like that.
I need to tear into mine some time this weekend.
So I finally go to it this afternoon.  As was mentioned, some traces on the back of the cluster were corroded.
Judging by the mess of it, I'll be in there again for another problem later.  My bike has 138,000km in case you are wondering.
Al last...  I can contribute to this forum.  Here are pics of my repair:
This is the first fault I found.  It is the ground for the LCD.  The trace was broken, no continuity.
I thought I had it licked, but it wouldn't work after hookup, so I looked further, and found the hot side also broken(I'm sure I checked it FIRST!)
So there you have it.  If your LCD is dead, AND you checked the CLOCK fuse, this is likely your fix.
I used 22AWG solid wire.  I crimped and soldered the crimp after, just to be sure.
Hope this helps someone else someday.  VFRD has helped me A TON since I got my viffer.
Bump
The LCD on my '98 is fine, except for the odometer. Everything else works and displays properly but no display on the odometer. No corrosion on the circuit board, help please!
I've heard of people making "curtains" to keep water off the PCB when they are in there changing bulbs ect.
End of thread · 8 posts recovered Wayback Machine snapshot 24 May 2012
