If i downshift into 1st goint like 12mph or less it goes insmooth as butter.
Anyone else notcing this? Is it putting wear on the shaft?
[image: View Post]UltraMagnus, on 07 July 2010 - 05:21 PM, said:
Seems like if i downshift into first 15mph or over i get a noticable "clunk" into gear. And it almost feels like the rear wheels is locking slightly.[image: View Post]UltraMagnus, on 08 July 2010 - 01:21 AM, said:
Seems like if i downshift into first 15mph or over i get a noticable "clunk" into gear. And it almost feels like the rear wheels is locking slightly.[image: View Post]UltraMagnus, on 07 July 2010 - 08:21 PM, said:
Seems like if i downshift into first 15mph or over i get a noticable "clunk" into gear. And it almost feels like the rear wheels is locking slightly.[image: View Post]mello dude, on 07 July 2010 - 07:12 PM, said:
Seems like if i downshift into first 15mph or over i get a noticable "clunk" into gear. And it almost feels like the rear wheels is locking slightly.[image: View Post]rangerscott69, on 07 July 2010 - 06:05 PM, said:
You need to be going slower. It's just like shifting into first while moving in a vehicle. It usually doesn't want to shift into 1st. It's like an anti-screw up. Car scenario: You don't want to be say in 5th gear and hit 1st gear. Bye bye drivetrain. Bike scenario: Shifting into 1st while going to fast can lock up the rear wheel.[image: View Post]Monk, on 07 July 2010 - 09:28 PM, said:
Like Mello Dude said it's kinda instinctive, You need to work on your rpm's with the rear tyre speed.... Sound's like you're low on rpm's.... You don't want to just blip the throttle, you're going to want to bring the rpm up to match the speed and hold the rpm up after it "slides" into gear. If you just blip the thottle to get it in gear then let off again the rear wheel will curp/slide big time..... Same with all gears..... Retired semi driver..... if it wasn't done like this with 45000 pounds I'd be dropping trannies all over the road... or jack-knifing......[image: View Post]UltraMagnus, on 07 July 2010 - 10:06 PM, said:
When i upshift i do.[image: View Post]Trace, on 07 July 2010 - 10:17 PM, said:
When i upshift i do.[image: View Post]UltraMagnus, on 08 July 2010 - 12:15 AM, said:
Like Mello Dude said it's kinda instinctive, You need to work on your rpm's with the rear tyre speed.... Sound's like you're low on rpm's.... You don't want to just blip the throttle, you're going to want to bring the rpm up to match the speed and hold the rpm up after it "slides" into gear. If you just blip the thottle to get it in gear then let off again the rear wheel will curp/slide big time..... Same with all gears..... Retired semi driver..... if it wasn't done like this with 45000 pounds I'd be dropping trannies all over the road... or jack-knifing......[image: View Post]UltraMagnus, on 07 July 2010 - 09:15 PM, said:
Like Mello Dude said it's kinda instinctive, You need to work on your rpm's with the rear tyre speed.... Sound's like you're low on rpm's.... You don't want to just blip the throttle, you're going to want to bring the rpm up to match the speed and hold the rpm up after it "slides" into gear. If you just blip the thottle to get it in gear then let off again the rear wheel will curp/slide big time..... Same with all gears..... Retired semi driver..... if it wasn't done like this with 45000 pounds I'd be dropping trannies all over the road... or jack-knifing......[image: View Post]jaimev34, on 07 July 2010 - 10:37 PM, said:
Like Mello Dude said it's kinda instinctive, You need to work on your rpm's with the rear tyre speed.... Sound's like you're low on rpm's.... You don't want to just blip the throttle, you're going to want to bring the rpm up to match the speed and hold the rpm up after it "slides" into gear. If you just blip the thottle to get it in gear then let off again the rear wheel will curp/slide big time..... Same with all gears..... Retired semi driver..... if it wasn't done like this with 45000 pounds I'd be dropping trannies all over the road... or jack-knifing......[image: View Post]UltraMagnus, on 08 July 2010 - 01:17 AM, said:
Like Mello Dude said it's kinda instinctive, You need to work on your rpm's with the rear tyre speed.... Sound's like you're low on rpm's.... You don't want to just blip the throttle, you're going to want to bring the rpm up to match the speed and hold the rpm up after it "slides" into gear. If you just blip the thottle to get it in gear then let off again the rear wheel will curp/slide big time..... Same with all gears..... Retired semi driver..... if it wasn't done like this with 45000 pounds I'd be dropping trannies all over the road... or jack-knifing......[image: View Post]SEBSPEED, on 08 July 2010 - 02:38 PM, said:
