I'm a big Givi fan. Love their hard luggage for the durability, waterproofness, and overall quality. (Yes, I know that Givi MAKES the OEM cases, too).
VFR1200 with OEM cases: http://static.blogo....ccessori_06.jpg
With Givi V35 side cases ** (click the small pics to get larger ones): http://www.giviusa.c...A&mo=VFR-1200-F
** Also note above that I will NOT use the Givi mounts, but will use the SW-Motech mounts (see below).
Obviously, the OEM side bags for the VFR1200 look great, and they do not require any additional mounting hardware. But they are hundred more than the Givi V35 bags, and have less capacity as well.
The Givi V35 contoured bags appear to be more durable, and I don't know that I've met a piece of Givi hard luggage that wasn't rock solid and waterproof. The Givi's would also require additional mounting hardware, and I've been looking at the SW-MOTECH Quick-Lock Sidecarriers. These are tubular and mount to the bike with fasteners that, if you want, can be removed completely from the bike in a matter of seconds without even knowing that they were there:
http://www.twistedth...tview/5492/804/
Further, SW-Motech offers a top case rack that would work with my existing Givi E460 top case, in the event that I need more room:
http://www.twistedth...tview/5495/804/
Even with the extra mounting hardware, the Givi setup would come in quite a bit cheaper than the OEM stuff:
Honda OEM sidecases, top case, top case mounting bracket, pad: Best deal I can stroke on the $2,250 MSRP total price = $1,800.00.
Givi V35 cases, quick-lock sidecarriers + adapter plates + locks, top case rack + adapter plate = $970.00
(I have the E460 top case, so to be completely fair when comparing prices, add $208 to the Givi total to make it $1,178.00).
So in my case (pun intended!), my price differential is close to 50%!
No, the V35's don't look as clean as the color matched OEM cases, and they don't use the factory mount points (but I can remove the Givi sidemounts in seconds). But they are larger than the OEM panniers, and I perceive them to be more durable.
So the question is: Are the benefits (and drawbacks) of the OEM cases worth nearly DOUBLE the price of the Givi setup? Thanks for any comments.
