[image: View Post]swimmer, on 25 August 2010 - 10:36 AM, said:
[image: View Post]SEBSPEED, on 25 August 2010 - 05:44 AM, said:
Do you store the bike outside much? It's not really old enough to be having ignition problems?
Then again, you live in Tucson, so you must be storing it inside, or it would have been stolen by now...
Is your key very worn down? Got a spare that you can try, to see if that might be the issue?
In the one year that I have it had it has always been kept outside in my car port. I am sure it happens but I don't know of anyone who has had their motorcycle stolen here. Having 1) a VFR and 2) a VFR with side cases makes it pretty unlikely that it would ever be stolen.
It's a newer key that I am using.
I didn't mean for that too sound too negative; I have a friend in Tucson whose F4i was stolen. The dealership that he picked his new helmet up from(the day after the bike was stolen) told him that the average lifespan of a bike kept outdoors in Tucson was 90 days...
Don't really know what to tell you, except to pull the ignition & have a locksmith check it out. Not sure if you can order a new one from Honda with the same key code, so you might end up buying a used lock set. (ign, gas cap, seat lock)
[image: View Post]YoshiHNS, on 25 August 2010 - 10:53 AM, said:
The ignition on the Katana I worked on was held on with 6mm security torx bits. Can get them at HF. They were held on from the bottom, so you'll probably have to take the front fairing off for easier access.
It's much easier to just pull the handlebars & top clamp.
