[image: View Post]SEBSPEED, on 10 September 2010 - 01:42 PM, said:
[image: View Post]JamieDaugherty, on 10 September 2010 - 01:05 PM, said:
Something to keep in mind is that the VF's require very long forks in order to maintain clearance with the front cylinder head and/or radiator. This is critical and should not be overlooked or minimized. It's been mentioned here (and other places) that forks off newer bikes can be made to work. I've not been able to accomplish this without significant custom parts, such as special triple clamps or fork tube extenders. It's possible to make an upgrade like this work, just be careful when measuring everything to ensure that you have clearance at full compression of the forks from lock to lock.
Don't know if you've already tried this Jamie, but I've measured F2 & F3 forks and found that their free length is the same as VF1000R forks, if mounted flush with the top triple clamp. So, given the proper spring rate, they would make a great intermediate upgrade for the big F's & R's, and also for the 750/700F (if combined with 1kF/R triples & modified steering stops).
One could then add risers and a handle bar to mount on the top triple, or use tall Helibars/Convertibars/Vario bars mounted under the top triple.
Yes, most newer forks are too short, but with proper homework, a retrofit isn't necessarily as hard or impossible as it sounds sometimes.
Indeed I have! It took a little stroll down memory lane to find out where I put that info in my notes. It's been so long that I felt the need to double check the numbers on some parts laying around, luckily my notes were correct:
VF1000R:
Free length = 835mm
Stroke = 150mm
Compressed length = 685mm
CBR600F3:
Free length = 785mm
Stroke = 130mm
Compressed length = 655mm
That's a difference of 30mm. Clip-ons are usually about that thick, so running the F3 forks flush with the upper triple should work. It would appear that the only way to run clip-ons would be to use riser bars and mount them under the clamp. "Superbike" style bars like you mention would probably be the best way to go.
