Air filter compatibility: vfr700 and 750
3 posts Started 30 Sep 2010 Last recovered post 30 Sep 2010 Wayback Machine snapshot 4 Jun 2011
As I understand it, the 86-87 VFR700 and VFR750 parts are compatible.
How about the carbs, are they the same?
Before I go pull the trigger and buy it, will a 750 air filter fit the 700?
Thanks for info...just wanted to clarify so I didn't waste time on the wrong air filter...
The air filter is the same for all 86-87 VFR700/750 models.
The carbs are a bit different. The 700 is a Keihin VD BAB and the 750F is a Keihin VD BAA. That said, if you swap them as a complete assembly they are interchangeable between the 700 and 750.
The 86 VFR700/750 are 95% interchangeable, the exception being the engine internals. The 87 VFR750F2 adds some electrical (ignition, wiring, gages, etc.) changes over the 86.
Perfect, thanks!
End of thread · 3 posts recovered Wayback Machine snapshot 4 Jun 2011
