grab another BIG cup of coffee!!
todays how to.. save your R/R hopefully from going bonkers on you. :computer-noworky:
this is my personal set up that i have done to many bikes with great results.
this his HOOPDC'S 95 vfr750. :fing02:
Regulator rectifiers absorb 3 strong alternating currents (AC)
from the stators yellow wires, and change them to a steady stream of direct current (DC) via the red wire. .
if the R/R gets to much juice it sends the overflow to the ground with the green wire..
however.. the green wire is kinda wimpy and runs to the main harness and meets a bunch of other wires with juice going through them..so the flow gets a bit hot...
and heat build up is what kills the R/R
ok.. take a sip of coffee...breath..
if your not deaf like me ..put on AC/DC's "long way to the top"
sooooo, what you need!
i am assuming you know who to solder and have an mini or electric soldering iron,..if not.. get one and practice a bit.
you need green wire,eyelets, a brown wire, connection ends, a computer fan, heat transfer compound, a wire brush and a pick. :comp13:
[image: Posted Image][image: Posted Image][image: Posted Image]
take r/r and stator wires ..disconnect them. take the pick and remove the tanks from the blocks and scrub them clean!
IN YOUR CASE....
CUT THE BLOCKS OFF!!
ADD MORE YELLOW>> AND HARD WIRE THE STATOR TO THE R/R :fing02:
now.. take the eyelets and solder them to the green wires. if your wire is thin you can double up or triple if needed.
make 3 off them about 5 inches long.. you can cut them short if needed.
find your tail connection and splice in one of the eyelet extensions and bolt it to the frame .. taking a little paint of helps with the connection. do this with the green wire coming from the R/R and the bunch of green wires up at the front of the bike.
[image: Posted Image][image: Posted Image][image: Posted Image][image: Posted Image]
take your computer fan..(this one from a dumpster..RECYCLE!)
and fit it over your R/R.. you may need to make a mounts for it.. this one was perfect.. just needed a shave to open the spot for the plug.
drill the mounting holes.. then remove the R/R and put lots of heat transfer compound on it.. this is just a dab.. dont be shy with it. :biggrin:
mount your R/R and fan.. ground the fan neg wire and and the connection plug on the positive. splice in the brown wire to the power wire for your brake light. brown is power accessory on hondas. :fing02:
and your done! :bliss:
this may seem like overkill... but overkill in the garage is MUCH better that a dead bike on the road! :fing02:
now bug some mods about pinning this post! :biggrin:
