Hi guys. I need to tap into the font of knowledge again, and hope you can help me!
I've been looking to install a CBR F4i shock on my Vf500, and have loosely assembled everything so I can have a bit of a measure up for the linkages.
I've noticed that the lower link sits to one side in it's bracket, and that the top mount for the shock seems to be drilled on an angle - that is the holes aren't level when viewed from the rear of the bike. It's niggling me that all this stuff doesn't sit right in the middle of the brackets, although I notice from CMSNL.com's parts fiches that there are no spacers either side of the shock linkage or the lower suspension link. Is this why? Are Honda's tolerances that wide?
Has anyone got any measurements that I can take to make sure this frame is straight? It looked OK before the bike was stripped, but now it's just a bare frame I want to make sure it's right before I attach anything to it.
Any information would be extremely gratefully received.
If it does turn out to be straight, I'll be starting on that exhaust I first mentioned about 6 months ago in the new year!!
Thanks in advance!
Gareth
Thanks in advance!
Gareth
