To make a google map route resize the map to see your beginning point and right click on the map point you want to begin with then choose -directions from here- in the menu that pops up
drag the map to your destination then again resize to find it better and right click again choose -directions to here-
resize the map to see the entire route then right click on the point of the map where you want it to be centered and right click -center map here-
click -link- at the top righthand side of the map find the code in the box labled -Paste link in email or IM-
highlight the code in the box then right click with you mouse and copy the entire code
Method One for adding code to post
click other styles then chose embed google map
choose google map embed
paste the map code into the box some browsers will error out if that is the case then try method two
Method Two
in the post screen box left click and choose paste
paste the map code into the post screen text box then put map tags at the front of the code and at the end of the code
Map tags will have an opening tag and a closing tag
this is the raw map code pasted into the post
http://maps.google.com/maps?f=d&source=s_d&saddr=Colorado+Springs,+CO+80906&daddr=17+West+Palmer+Street,+Franklin,+NC+28734-3046+(Franklin+Motel)&hl=en&geocode=FSn9TwIdiS3B-Skjsyf5gFwThzG4dfnOaMZjJw%3BFR3PGAIdaqUH-yHJpii3nA0k3w&mra=ls&sll=39.300299,-95.712891&sspn=29.993673,86.220703&ie=UTF8&ll=36.385913,-93.515625&spn=15.646283,43.110352&z=5
this the same code with the map tags added
[map]http://maps.google.com/maps?f=d&source=s_d&saddr=Colorado+Springs,+CO+80906&daddr=17+West+Palmer+Street,+Franklin,+NC+28734-3046+(Franklin+Motel)&hl=en&geocode=FSn9TwIdiS3B-Skjsyf5gFwThzG4dfnOaMZjJw%3BFR3PGAIdaqUH-yHJpii3nA0k3w&mra=ls&sll=39.300299,-95.712891&sspn=29.993673,86.220703&ie=UTF8&ll=36.385913,-93.515625&spn=15.646283,43.110352&z=5[/map]
[map] - opening tag [/map] - closing tagthis is the result
Full Size
