EXO StormRider Heated Vest
1 posts Started 27 Jan 2011 Last recovered post 27 Jan 2011 Wayback Machine snapshot 1 Feb 2011
For Sale Here - my EXO2 heated vest.
I simply don't use this vest much any more and I'm recently re -MARRIED. So..... I've been asked to unload some of the stuff that is filling my closets and storage areas. No Problem - this item originally sold for over $250 bucks and it works great - it's the top of the line - a premium product. Even heat all over the garment and I got a great fit. The size medium was the correct fit my 40 inch chest - worn with a long sleeve shirt under.
I used to run it with a standard 12 volt temp controller - standard COAX connector.
The EXO2 vest works better than Gerbings and better than Powerlet heated products. Made in the UK.
If you don't want to wear a long sleeve liner under your jacket - the vest is PERFECT. Did I mention it's really warm?
And the vest is in P E R F E C T shape. No runs in the fabric, no funny smells, it's never been abused and it WORKS. If I had the original packaging I'd sell this "as new" since I only used it a few times.
$15 ground shipping in the USA. $85 for the VEST - $100 TOTAL PayPal only. It goes on Ebay next week.
Here's what the Web Page has to say about the vest :
StormRider Heated Body Warmer
Manufactured using a new, breathable, lightweight, waterproof & windproof fabric called AirXtream. Its body hugging characteristics help the resulting heated garment to look equally stylish on men or women.
Indeed the EXO2 FabRoc� Heated panel technology is so versatile and robust it can even be machine washed!
The heated panels are located at the upper back, kidney area, chest and front shoulders and maintain a constant 50�C.
The vest is powered by straightforward connection to the motorcycle battery via the supplied loom or from an optional rechargable power pack.
( Note: When using the optional power pack sold separately, the heat operates in the kidney area only).
Power Requirement approx. 2.5Amps at full power. StormRider is the most energy efficient product of its kind on the market today, giving bikers the maximum evenly spread temperature performance across the entire bodywarmer�for the lowest power draw from the motorcycle battery. The superb AirXtream fabric will retain the heat generated to serve the torso whilst wicking moisture away from the body to keep the user dry and comfortable all day long.
Here is the Web Page "catalog view" of the vest.
http://www.denniskir...ix/28201359.jpg
End of thread · 1 posts recovered Wayback Machine snapshot 1 Feb 2011
