Gopro lcd bacpac
[image: View Post]vfr661, on 01 February 2011 - 09:43 PM, said:
I can't believe they want $80 for it. I'll pass for now..I agree with you, $80 is a bit much, but I'm sure I'll pop for it, probably sooner rather then later. Least if comes with new doors so it can be used with the existing housing.
[image: View Post]Knife, on 03 February 2011 - 02:43 PM, said:
I want one. But now I have to buy the HD version of the camera (I have the original version). About $380.00 total for the camera and BacPac, I think. Not cheap, but I'll likely do it anyway.I've seen the camera's for a lot less than the $300 MSRP. Anywhere in the $220 - $250 range. Still pricey, but almost like getting the BacPac for free. :biggrin:
I bought the screen. It's nice, but does seem to hog up some battery even if you set it to turn off automatically after a bit. One big advantage: it spells out the menu options when you cycle through them. I don't know about anyone else, but I have yet to memorize 'GoPro'-speak, so I always had to carry around the manual so I knew what changes I was actually making. My two big complaints with the screen: 1) it takes the space for the add-on battery pack, so you can't run both at once and 2) the LCD cannot use the same rear portion of the protective housing as would be used for the add'l battery, so you have to carry around all the case halves and swap them around. Very annoying.
Mike
can you delete pics/video using the screen menu?
Mike
Yes, but you can already do that without the screen as well. Having the screen just gives you the advantage of having something that spells out the command and explains what it will do, as opposed to 'dLt' or whatever the dinky LCD screen on the front tells you.
Mike
Mike
Does the unit not have its own battery? Reading the info for it, I was sure the unit had its own battery that would power it and give you extra battery life for the camera as well. Thats my biggest issue with the GoPro is lack of battery life. I get about 3hours on a battery shootting @ 720.
And I do the same with the settings menu, I know a few like upside down shooting and the res setting but all the others I have no idea about.
Just to be clear, the box didn't fall off, it opened and everthing inside fell out. So they put a zip around the box.
We had a guy at T-mac this year that lost the whole camera(w-pack). speculating that the added pack might of been part of the reason for the box opening up and losing the system.
There were other reasons that could have caused it, but the solution was to zip-ty the box(someone elses). Just an FYI
Good to know... thanks. I will also tether mine.
It could have been that it wasn't closed correctly, or that it was mounted on the front finder, and got to many hits from not being sprung.
I purchased one a month or so ago. The one thing that disappointed me was that while on the fly do to bad angles in certain mounting positions and it being hard to see in the sunlight I just can not see the darn LCD to verify that I did indeed press the start/stop recording button. Still, no regrets, it does make the camera more user friendly.I bought the screen. It's nice, but does seem to hog up some battery even if you set it to turn off automatically after a bit. One big advantage: it spells out the menu options when you cycle through them. I don't know about anyone else, but I have yet to memorize 'GoPro'-speak, so I always had to carry around the manual so I knew what changes I was actually making. My two big complaints with the screen: 1) it takes the space for the add-on battery pack, so you can't run both at once and 2) the LCD cannot use the same rear portion of the protective housing as would be used for the add'l battery, so you have to carry around all the case halves and swap them around. Very annoying.
Mike
Mike
Not to my knowledge
It's charging now and I hope to test it on Sunday.
The box that protects the camera seems pretty secure for it to just open but I might just do the extra steps to secure it.
Also, the tethering of the suction cup will be a must just as added precaution.
I own the battery backpack. It uses the same back door as the lcd backpack. I dont see how changing the back door on the casing would effect the clamping mechanism whatsoever. Mechanically its exactly the same except its a little deeper.
However there can defintly be user error on putting on the new door and also clamping it shut improperly.
Also when i was shopping for my batteyr backpack and reading the gopro forums ive read alot about the LCD bricking gopros. Ide personally hold off on it till they get the new firmware sorted out.
Those with software issues probably need to update the OS on the camera. I had to on mine. It's free on their website.
Mike
Not only because it spells the cam options, but you can actually see what you are shooting when setting up the cam on a mount location.
It does suck battery life.
Solution: get a battery pack. it serves as a stand alone charger with mini USB adapter and comes with one battery.
No, you cannot have both on the gopro.
I have the battery pack in my tail bag charging one battery. I have a 12v plug from under the seat.
When the gopro goes low on battery, I just swap batteries.
