KPerham
Well, screwdriver was my best idea!
Must be a misprint in a manual somewhere, I swear that's the second time I heard that number.
No good way to do it now, just keep working at it. Big channel locks or something. Find a more solid part of it and hammer it?
Strap wrench might still work...
A bit too much oil on the cartridge surface to get the strap wrench to grip, K. Plus no strap wrench leverage room with the exhaust pipe and coolant hoses in the way. Removing the evap. canister helps access a bit but still too tight.
whiteboyslo
strap wrench? looks like there may be enough left there to grab onto.
Mike
The camera angle is deceptive. It's really too tight for a strap wrench.
canadIANviffer
Put a steel hose clamp on it as close to the base as possible.
Tighten the clamp with a socket as tight as you can.
Grab a big flat screwdriver and a hammer and tap it ever harder until it starts to turn.
That oughtta do it!
Ah-ha! I like this. I have a 5" diameter worm drive clamp at work that I can try tomorrow.
Jmmymc750
well, you are already tearing up the filter. Continue. One of those "claw" type filter wrenches works for me in this situation (was an oil changer for awhile after college, and brake guy, tire guy, etc at the speedy lube - seen lots of these). Wal mart has the filter wrench I refer too, and I prefer them to the screwdriver method. You may have enough room there for the claw (they look like pliers, but big), and once you grab it and crush the filter (or its remains) a little, it will deform the mating surface and you should be able to get the thing spinning.
Otherwise, just tear off the filter, and use some slip joints to get the base off.
Cheers!
P.S. +1 on the hand tight.
Trying not to buy new tools here, Jimmy. Though it may come to this. There may not be enough room for big pliers.
Vecky5
I did the same thing you did. I completely destroyed the filter with a screwdriver. I ended up taking off the evap cannister to gain easier access to the oil filter then grabbed the filter (or what was left of it) with some channel locks. It eventually broke loose then spun right off. What should have taken about 30 minutes and a few beers total took over an hour plus more beer than originally planned (which is not such a bad thing looking back).
My channel locks don't quite fit around the cartridge, but removing the evap. canister does provide a bit more access from the right side. Good idea!
joneill
dendron
This filter (Wally World Super Tech ST7317 made by Champion) was installed and torqued to spec (20 ft.lbs -- this just HAS to be wrong Honda!) per the VFR service manual on the last oil change. Just before reaching the 20 ft. lbs click the filter wrench began to spin on the cartridge. I've since come to realize through a consensus of other forum contributors that this should be hand-tightened + 1/4turn on said filter wrench, which is certainly less than 20 ft./lbs.
So, no leaks all was well and good until it was time to remove this filter cartridge on the next oil change. No budgee!! Soaked the mating surface w/PB Blaster penetrating catalyst, waited 20 minutes for effect, hammered a screwdriver through the filter in an attempt to gain leverage, tugged counterclockwise. Still no budgee, except for the screwdriver ripping through the soft metal cartridge. Now, I've run out of options and was hoping to solicit possible solutions from the board. Thoughts anyone?
CanadianVFR has it right.
Use the worm gear hose clamp and tighten at the base. Tapping the hose clamp will get to start to turn. If you tighten it with a socket and extension. Use the same socket and extension to tap the hose clamp. I no longer use a torque wrench on the filter, I tight by hand. When a filter is this hard to get off, it usually means that no oil was applied to the filter gasket before installation.
Jack
Thanks Jack for that confirmation. Yeah, I'm thinking this is the way to try. I did apply a thin coating to the filter gasket on installation, but maybe it was too thin, or, maybe...Honda's torque spec is WHACKED! :goofy:
