Michelin Pilot Road 3
at the very least they get points for knowing the target audience.
Dang, not another new tire, I haven't even found the limits of the PR2s yet....although I did get the front end to chatter a bit last week on a couple very tight turns in the twisties..... : :mellow:
Beck
95 VFR
Stuff that a normal tire would slip on, these will hook up and be planted.
Good tire to take on a long trip with gloomy forecast.
[video: http://youtube.com/embed/YS8XkFhSRX0?html5=1&fs=1]
The way I understood the video I saw, they moved the double compound area(widened the soft compound area of the shoulder), but no mention of changing the compound itself.Is it just the micro sipes they added to the tires?? I suspect they are claiming new compounds too.
Beck
95 VFR
I agree, it's been said that sipes help keep the tire cooler which will give it better life (which I'm not convinced of), but on the other hand I'd think that flix would make it heat up more in the first place, and also cause it to wear faster. But the fact that they left more of the solid rubber(the big sipes are more to the side) in the middle will help the wear factor on the straight roads.Think ill be ordering another set of PR2's soon before there not available, as far as Im concerned they are still the holy grail of tires for vfrs. with all those extra sipes i wonder if they will last as long. alway thought the current ones were fantastic in the rain certainly better than the angels.Hopfully some one needs to try them and let us know if they really are better or just marketing hype.
I'm getting 8000 + out of my PR2's F&R.
I hope they don't quit making the 2's.....But if they last too long they lose money......
I haven't found anything that brings it up. If they did I would think they'd make it part of their selling points....Does it state anywhere if they changed the static profile of the tire or not?
I am very happy with the grip that it gives, turn in to a corner now fells much quicker.
I am about to get the rear as i have a new rear wheel , a 8 spoke 5.5x17 from a 3rd generation, this has been powder coated
gold in the HRC colour to match the front wheel.
but I can not get a 180/55/17 tyre locally, but can get it on the net.
But i can get the 170/60/17 tyre tomorrow if i what,
so what should i do!!!!
this tyre is officially launched in the UK at the end of march and has a big launch in Ireland for the trade.
but there where some tyres around from the start of jan. they are starting to dry up quickly.
jools
P.S i will post some photos of the 8 spoke wheel after i have fitted the tyre.
I have had the Michelin PR3 on the front of my VFR750 94'model for about a week, I have done about 30 miles so far.
jools
Wait for the 180, you'll be happy you did!
Can't wait for the pics.
after watching video again those micro sipes are so small under any kinda of tire flex especially braking you would think they would close up and have no advantage in the rain.I agree, it's been said that sipes help keep the tire cooler which will give it better life (which I'm not convinced of), but on the other hand I'd think that flix would make it heat up more in the first place, and also cause it to wear faster. But the fact that they left more of the solid rubber(the big sipes are more to the side) in the middle will help the wear factor on the straight roads.
Not disagreeing, anything that helps is always welcome, but it still comes back to us being smooth.......... I had some sipes cut into my Jeeps tyers when I was living in Denver and we got this hard dry ice and the tyres worked way better with the sipes, so I'm guessing what we see isn't what test results show the tyre manufacturers.after watching video again those micro sipes are so small under any kinda of tire flex especially braking you would think they would close up and have no advantage in the rain.I agree, it's been said that sipes help keep the tire cooler which will give it better life (which I'm not convinced of), but on the other hand I'd think that flix would make it heat up more in the first place, and also cause it to wear faster. But the fact that they left more of the solid rubber(the big sipes are more to the side) in the middle will help the wear factor on the straight roads.
Quicker than what tire, please?
Quicker than the old worn-out one he took off I think. :laughing6-hehe:
They where ( Don't Laugh) pirelli dragons front and rear.
just been out today these are fantastic, Its Like i have a new bike.
I have not tried them i wet yet but in the dry they are amazing
:[image: Posted Image]
002
jools
Let us know how they do in the wet weather. I would like ot know as I live in the rainy area. :biggrin:
I agree with you. I'd like to see if anybody besides the aftermarket siping companies make that claim about reduced heat. I would think more tread squirm = more heat. In terms of getting rubber softer in cold weather, that might be a good thing, but definitely not for tire life. Hmmm...
from my limited experience with rain tires on the track quickly found out you have to run those tires with high tire pressure or sipes will close under heavy braking and accelerating then your sol. the sipes are huge on a track only rain tire, I know they are a completely different tire but principle should be the same. i guess thats why i questioned the value of those micro sipes.Not disagreeing, anything that helps is always welcome, but it still comes back to us being smooth.......... I had some sipes cut into my Jeeps tyers when I was living in Denver and we got this hard dry ice and the tyres worked way better with the sipes, so I'm guessing what we see isn't what test results show the tyre manufacturers.after watching video again those micro sipes are so small under any kinda of tire flex especially braking you would think they would close up and have no advantage in the rain.I agree, it's been said that sipes help keep the tire cooler which will give it better life (which I'm not convinced of), but on the other hand I'd think that flix would make it heat up more in the first place, and also cause it to wear faster. But the fact that they left more of the solid rubber(the big sipes are more to the side) in the middle will help the wear factor on the straight roads.
smooth is always good but you can still have unexpected heavy braking in the rain on the street
002
jools
Can you post more pics of the complete bike with those wheels? That color is sweet!
[video: http://youtube.com/embed/xG_X7hijpbw?html5=1&fs=1]
002
jools
Heck with the tire i wanna see the bike !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you can't wait, get the 170s and use your original 5" rim, turn in will be quicker than on a 180. As it is the PRCT2s are a little bit slow on the turn in in general, a wider tire could just amplify that a bit more. Wider tire/wheel is also = to more wieght, but the wider 8 spoker is definitley 10 times nicer looking than the 4th gen 5 spoker! :fing02:
jools
Beck
