VFR is road ready
7 posts Started 10 Apr 2011 Last recovered post 11 Apr 2011 Wayback Machine snapshot 4 Jun 2011
I finally got most everything ready to ride on my VFR700. Mechanically not much was required. The mufflers were replaced with VTR1000 units. An aftermarket regulator was installed, The multiple key system was simplified so that only one key is needed. The fork seals were replaced. The body work was well worked on. I was able to substantially keep the original graphics intact. I made some carbonfiber dash panels to replace the broken panels. One of the mid main fairing panel mounts was missing so I fabbed one with some stainless steel tubing. I have a couple of minor body issues noticed as I installed the panels and I will repair them.
vfr700 right front The old 700 still looks pretty clean. The end of the center cowl was broken off and the side cowl had broken off tabs.
vfr700rt3/4front
vfr700 left profile Ready to ride, almost, front blinkers need to be attached.
vfr700 dashboard My VFR dashboard. I replaced the side dash panels with some carbonfiber ones.
I need to get it inspected and licensed.
Looks Good!
Enjoy :cheerleader:
Looks great!!! How 'bout a ride report once you ride it??!!!?!?
C
Looks great I like it. I like the carbon dash inserts
Looks classy!
Now go for that ride but donot miss the apex :biggrin:
Looks great, you will enjoy that!
GREAT looking bike! The RWB paint job cannot be beat. :fing02:
End of thread · 7 posts recovered Wayback Machine snapshot 4 Jun 2011
