Engine cuts out while riding
6 posts Started 16 Apr 2011 Last recovered post 16 Apr 2011 Wayback Machine snapshot 30 Apr 2011
Yesterday on the way to work, my 06 VFRs engine cut out while about a half mile from home. I quickly pulled the clutch and restarted it, and didn't have any problems the rest of the way. However, on the way home from work, I took the backroads and it cut out on me like ten times. I was just maintaining 45mph and it died. The instrument cluster stays on, but the lights look a little dim. I also noticed that if I haven't ridden it for a day or two, it sometimes has a hard time cranking over when I hit the starter.
I'm wondering if its time for a new battery, don't this one has been in there for maybe four years. Could it be a problem with the charging system?
The bike is all stock except for a PCIII that's been in there for a few months, and a de baffled exhaust.
Anyone had a similar problem?
A good battery is needed for these things to function so I would start there, But if i ever have any Ign. cutout issues I Always bypass a Power Commander to be sure it is not the issue. :fing02:
Good luck.
Thanks for the quick reply. I'll try replacing the battery and see if that works. It hasn't had any problems with the PCIII installed until now, and I installed that about 800 miles ago.
However if the battery doesn't work, I dig in and bypass the PC.
Yeah my track bike CBRF4i was running fine during a Barber event and then during the 3rd or 4th session it just started dying, I unhooked the PC3 and it worked great!
Not saying that's it, but it's a possibility because it causes the normal CPU signals to run thru it.
After the battery it's the first thing I would remove from the diagnostic picture. :fing02:
Make sure there are no loose wires and bad ground?
C
Problem seems to have been a loose ground at the battery. Tightened it up and checked all around the bike for other loose wires. Seems like its ok now.
Thanks for the help everyone!
End of thread · 6 posts recovered Wayback Machine snapshot 30 Apr 2011
