Excellent EZ Pass mount location
1 posts Started 8 May 2011 Last recovered post 8 May 2011 Wayback Machine snapshot 14 May 2011
Found a great mounting location for the EZ Pass transponder. If you remove the windscreen there is a small cavity underneath. The EZ Pass tag fits right in there and you can wire tie it to the connector right behind it. Mount the tag in the perfect spot and angle to be picked up by the tolls. Best part is the tag is completely hidden and pretty much impossible for someone to lift it.
This is a semi-permanent mount in that you can't easily swap the tag from the bike to the car but here in Pa they have motorcycle specific tags which charge a cheaper rate than the regular one so I just keep it with the bike anyway.
End of thread · 1 posts recovered Wayback Machine snapshot 14 May 2011
