It's set it and forget it. There is no adjustment or sideways play to worry about.
That said, you don't need to remove the swingarm to remove the collector box. The rear header pipes clamp to the top of the collector box. You should be able to reach the clamp bolts with a long socket extension.
Thank you very much That answers allot of questions. :fing02: :fing02:
However some hero instead of replacing the packing with new ones jammed a bunch of split spacers and put the clamps aiming towards the back so unfortunately I must access
it from the back.
Not to mention I have a brand new heat shield to install it would make things easier
