Powerlet Voltmeter
6 posts Started 6 Jun 2011 Last recovered post 6 Jun 2011 Wayback Machine snapshot 12 Jun 2011
I need a voltmeter, and I have a Powerlet port in plain view.
Does anyone know of a plug in volt meter for Powerlets?
That would be a pretty nifty idea especially for those that have several bikes with Powerlets.
Wouldn't this work? Just connect your voltmeter to the plug?
http://www.powerlet.com/product/basic-plug/275
Chuck
So do you not use the Powerlet for other things?? GPS or heated gear?? Would you want to add a "Y" or something when you use those items or just not have the volt meter available all of the time??
I have not used the powerlet for anything.
Not much need to heated gear and the GPS is hardwired.
I guess at some point I would feel the need for a powerlet, but as of right now it just collects dust.
I would use it for charging the battery then Chev, get a quick connector and wire up a powerlet plug to the other end, then hook up the trickle charger to the powerlet plug! Thats what I do for the veefalo.
Get a Escort / Passport radar detector. Plug it into the powerlet. The radar detector has a built-in voltmeter. That's how I monitor for radar and voltage at the same time.
Mark
End of thread · 6 posts recovered Wayback Machine snapshot 12 Jun 2011
