Hi All,
Just finished fitting up the Juice Box Pro and Two Brothers M5 Carbon slip-on late last night and rode the bike to work this morning. I mainly did this mod to help with the low rpm surging and generally poor fueling at small throttle openings which is common with the stock setup, an ECU reset helps but was not a total cure for my bike.
All I can say is WOW...what a difference... fueling is now silky smooth and the low rpm surging is 99% gone. I used the #2 map supplied by Two Brothers for stock air filter and their slip-on end can. They also supply a map for the stock exhaust, both already preloaded into the Juicebox Pro.
The unit is capable of carrying 10 maps, each of which is adjustable without the use of a PC/laptop, a simple turn of a small screwdriver is all that is needed while out on the road. I'll be doing a few of my own maps once I get a handle on how each setting effects the system.
I will have to run a few tanks of fuel through the bike before I can make an informed comment on fuel consumption though...!
So far so good....well worth the money and effort IMHO..!
One downside....those O2 sensor plugs are a bitch to get at .
Cheers,
Smithy.
Cheers,
Smithy.
