MRA VARIO SCREEN REVIEW
10 posts Started 20 Jul 2011 Last recovered post 22 Aug 2011 Wayback Machine snapshot 7 Apr 2015
After experiencing major buffeting from the stock screen on my 05', I installed a new MRA Vario screen. The plastic (or whatever the material is) of the screen seems very well built and shaped. It was a perfect fit that did not require any modifications. It looks very good in smoke color, in my opinion. It is easy to adjust on the fly, although they recommend not doing so for obvious safety reasons that I ignored.
After two weeks and about 1000 miles, I found that the plastic hinge pins on the hinge portion of the screen had loosened and that there was no way to tighten them. This resulted in my screen falling from its upright-most position at speed, which made the adjustment portion of the screen essentially worthless. By comparison, there was not much difference between the MRA and my stock screen with regard to wind deflection, anyway. But the buffetting was eliminated by the MRA, in any position. That's a very good thing.
Being the expert and humble wrench that I am, I popped (not pooped) out all the plastic hinge pins and replaced them with allen bolts and nylon lock nuts. Also, I added a 4" extension to the adjustable portion of the screen, which made a HUGE difference in wind deflection. Good for those cold winter days we never have in central NC. The bolts can be tightened just enough to allow the adjustable portion to be moved up and down, while being tight enough to keep it secure at speed.
I had a MRA Vario on my Blackbird that seemed to be much more stable and to have better deflection peformance. My understanding is that MRA designs each screen for each model of bike, they say, so you get what you get for the VFR. However, a little fiddling and she's just fine.
I believe MRA should strengthen the extent to which the plastic hinge pins maintain the position of the adjustable portion of the screen, regardless of my willingness to fix the problem myself. I paid $150 for the thing with the expectation that it would do what it was supposed to do. I recommend the MRA Vario with the caveat that the owner should be ready to make some mods to elicit the best performance. I believe also that the screen is overpriced. About $89.00 would do.
Hmm... I've had mine on for over 3k miles and nothing has loosened up yet. :(
Excellent write-up ... Thanks!
Pics please after you change the plastic screws.
Mine's gone almost 30k with no loosening. Glad to hear that you are adept at fixing it.
Just a quick question about height of the rider with the vario windscreen. I'm 6'0" and find that most anything other than stock height sends buffeting wind either just below the helmet or right into the middle of it making my head shake around quite a bit; for instance a zero gravity double bubble on my old street SV650S. I have a Givi on mine right now (was mounted when purchased) which I'm looking to replace because of the wind it sends right under my chin and makes it awful uncomfortable after 100+ miles.
Are those of you who have these screens a bit shorter than me that it would not me allow the same results?
I am 5'10", but use a Airhawk seat pad that may put me close to your head height, maybe. The MRA has eliminated any buffetting that I had with the stock screen. But the wind still hits me in about the same place without the screen extension I've mounted to the MRA. There are plenty of other variables that come into play, like your suspension settings, whether you have stock bars, and how you position your body at speed. Pretty subjective, really.
Howdy,
I am pleased with my MRA Vario. It does shed the cold well when full up.
The quality excellent after 5k of use.
No issues, except it takes more time to clean.
Mac
It sounds to me as the OP likes to make a lot of on the fly adjustments(no objection), so for the peeps that said they haven't had any problems with it loosening, do you make a lot of on the fly adjustments?
As for anything higher than stock allowing buff' I have a different extender that's higher and I'm 6'0" with no buffeting. One thing I'll say is for peeps that want to know if these things work, I had a Beemer RT with an electric screen adjustment control, and understand why the OP does a lot of OTF adjustments.
I could control the air flow to do pretty much whatever I wanted, from wind hitting my chest to going over my head : From negitive air on my back, to creating suction/drag on my back(enough that I could easily feel it). I also experimented with how it could cause drag on the bike at different speeds(it's electric why not),by locking my throttle then playing with the windscreen. It did make a differance..FYI.
A month or so ago, I bought a nearly new MRA Vario windscreen. The overall quality, fit and finish is excellent.........very comparable to the factory screen.
I've never been satisfied with the factory screen or the Zero Gravity DB that was on the bike when I bought it and I always thought the Vario might be a
good option. Like many of us, I'm always trying to reduce the turbulence and find "clean" "quiet" air. I installed the Vario and optimistically set off for a
test run. A mile or so down the road and I quickly realized this wasn't the solution. So I went back home and decided to perform a few tests. I cut a few
ribbons from my daughter's :cheerleader: pom poms..........a few at 6" long and a few more at 12" long............then taped them symetrically on the upper
edge of each windscreen and the upper edge of the Vario deflector. I left my dignity in the garage and set off on a dozen + test runs at varying speeds.
A couple of runs with the stock and ZG screens and multiple runs with the Vario deflector in different positions. The ribbons fluttered wildly at anything
over 45mph with all 3 screens. With the Vario, the ribbon fluttered more with each upward click of the deflector position. And "YES", there were more than
a few bewildered stares at my festive motorcycle decorations :blink: . The wind noise and turbulence were pretty much directly proportional to what the
ribbons were telling me..................more speed = more noise. I was a bit :pissed: , but was determined to reduce the buffeting and wind noise,
so I returned to the garage to think it over and have a :beer: . Then it hit me :idea3: .......I shouldn't try to minimize the wind, I needed to embrace the
wind and control it (if we want a perfectly quiet, wind free ride, we should buy a Gold Wing or just stick with cars). I decided to flip the deflector upside
down and immediately started searching for the smallest torx screwdriver that I had. My set only
went down to a T10..........the tiny screws are T8's...............so off I went to the store (in the car of course because of the :beer: ........needless to say it took
time and more than 1 beer to come up with such a great idea :goofy: ). I returned with the T8 and flipped the screen. Other obligations (and the beer)
delayed an immediate test run, but I was confident that it would work. That evening I went out for an hour ..........I hit some local twisty back roads and the
highway ...........speeds were mostly 45 -70................I'm :bliss: with the results. It looks a little odd, but it is very effective. The wind hits me in the chest and
my helmet is mostly free of turbulent air !! I'm a little concerned about the deflector catching too much air and affecting handling when it's windy +/or at
speeds of 70+............so a little more testing is in order and I may remove the deflector completely for certain rides. For reference, I'm 6'-0" and have
Helibars. Of course YMMV, but I've found my answer and couldn't be happier.
http://mail.aol.com/...As=IMG00640.jpg
End of thread · 10 posts recovered Wayback Machine snapshot 7 Apr 2015
