Laser Extreme Exhaust
Hate to say it but this is the place I got mine. didn't want 2-3 months but it was a good 30 days. When I called they told me that they don't keep them in stock and it was shipped via a real ship and that's why it took so long.I've always liked the Laser Extreme exhausts. I think the four pipes look and sound sweet. The one concern I have is where to get them. Laser's company website lists FosterRAD as the only USA dealer. I've read some really bad reviews about this company on a few motorcycle forums. Things like waiting 2-3 months to get their exhausts after purchase, it taking weeks to get a response from them if you are having problems, or not being helped, or not exchanging/refunding exhausts that didn't install right. Most of these complaints were from about two years ago. Is there some other source I can get them from that won't cost me a ton extra? Has FosterRAD fixed their customer service issues? Where did Laser Exhaust owners buy their pipes?
Sorry no help here.
Laser EXTREME is a perfect name as they are EXTREMELY Too Fricken Loud, I hate Lazers and anyone who runs them! :mad: Other than that , good luck! :laughing6-hehe:
Are there two different Laser exhausts for the 6th gen? The ones I saw at TMAC didn't seem too loud. Laser's website says only 1dB over stock but a deeper exhaust tone. Either way, the original question still stands. Is there any other reputable North American source?
Just did some more research. Apparently there are two inserts/baffles you can install in the cans. One is street legal and only 1 dB louder than stock. The other appears to be for off road/track use that dynos a few extra hp but they give no sound level rating on that one.
Check with Speigler USA, located in Dayton, Ohio. I purchased two Xtremes from them and I believe they still carry them.
Just got an email back from Spiegler. They stopped selling Laser Exhausts 2 years ago and don't know any other USA source.
parcels across the atlanticcan take some time......
A few will understand
300 km from a tank is more than respectable and I'll bet there's still a litre or two left in there when you decide to fill up not wishing to get stuck on the side of the road having run out of gas. Which means another 50-80 km easily.
At the track I've never squeezed more than 150-180 km out of a tank.
I only get 300km max that's empty in most cases or 100-200mls left. Track your full throttle most of the time, peak power every gear I don't look at mileage there just fill to about 1/2 tank each session as don't like full fuel load at track :-)
deltaboxii short answer no.
The torocharger is still sitting in my garage :wacko: it may sound strange but lost interest in fitting it because riding it without still leaves me with a wide smile. I will fit one day maybe unless offered the right $$ to part with it. I just don't ride enough these days & when I do it's trips away so reliability fuel range is important & the way I tend to ride I only get 300kms from a tank.
I was wondering what happened to that project :wink: , now I know. I was looking forward to seeing it on your trick VFR, bummer. Any chance you'll change your mind and install it?
Hi Arrow well short answer YES I'm going to install the supercharger kit after all. Did some regular maintenance just the other day & the bug bit me again only problem I have to do valve clearances & have injectors cleaned & flow tested before install. I'm going away April so going to start build after that which will be a slow process as there are a number of things I plan to do with the kit.
1. I hate the 5th gen radiator install especially the main outlet being squashed to fit so going to have a custom radiator made instead.
2. Looking at all the rubber hoses/clamps also don't thrill me so looking to have pressure fittings & hoses instead.
3. Standard oil cooler looking to up size again with pressure fittings & hoses.
4. Gauges for SC working out how to integrate into bike so looks factory.
5. New bike paint work.
I have another major bike trip oct so has to be finished & sorted by then :-)
Would a Torocharger from a 6th gen work on a 5th gen????? :goofy:
Dan said no, there are a LOT of differences between the kits. Critical mounting brackets and stuff.
Your need to rework a whole bunch of stuff to get it to fit.
Definitely looking forward to following this project!
The one I briefly rode over here had major issues with overheating so beefing up the oil cooler is a must, but then I'm sure you know this already.
hmmmmmmm after I get settled into my engineering job and money starts coming in, I may try to take the torocharger off your hands if you still havent fit it yet.... ;)
Fifth-gen or Sixth-gen? Maybe I haven't had a chance to ride mine enough to experience any overheating problems, but in the couple of shake-down runs I've done I never noticed the temperature getting high at all. The 5th-gen A&A kit replaced the OEM air/oil cooler with a trick water/oil cooler plumbed between the radiators. It does look a bit insubstantial, but I figured Dan had engineered it at least as well as everything else in the kit. I understand that the 6th-gen LHS radiator (thicker) will fit the 5th-gen, so I was planning to do that anyway, however.
Great to hear Roy, I really look forward to seeing the finished product :wink: ...
We are taking this thread off topic which I apologize for but will answer above.
My bike doesn't run to hot most of the time in current state but in Australia Summer can be fairly extreme at times & it's those days my bike will run high temp if not moving at a decent pace. Installing the SC will add allot of heat even if I'm not thrashing every gear with the extra hp like I do at present because I ride it like I stole it as bike is for fun I don't commute. The install for the 6th gen SC kit your decreasing cooling capacity needing to install a smaller 5th gen radiator RHS which troubles me even if the few that have installed the SC kit on a 6th gen report no dramas.
I also hate how the top RHS radiator outlet more or less has to be squashed out of shape to fit the hose, so will be looking into custom radiator setup to at least maintain the 6th gen capacity & address the RHS top outlet issue plan A. So trying to maximize the size of RHS radiator that is possible & even larger LHS radiator. Larger oil cooler would also be nice so looking at that as well but to do that it would have to be relocated into another position probably in front of motor but until I place SC in place & look at clearances that is plan B. Back up plan if I'm still not happy with temps is trying something like this plan C http://liquidintelligence115.com.au/
Sorry, 5th Gen
I'm not sure who supplied the kit (it was from over your side of the pond) and it was a few years ago now but the kit came with no change to the standard oil cooler circuit. It became quickly obvious that it did need a boost otherwise it regularly ran well above the fan temp.
It was a hoot though; throttle wheelies at 100mph+.
All done at Silverstone circuit I might add!
