Bad Front Brake Lever Light Switch
6 posts Started 15 Oct 2011 Last recovered post 16 Oct 2011 Wayback Machine snapshot 19 Oct 2011
Just a heads up for you guys to check and see if your brake light is activated by squeezing the front brake lever.
I found out last week my frt brake lever switch was bad...dealer ordered a new one for me under warranty and all is good now. :unclesam:
I check all my lights monthly, I discovered only few weeks back I had a blown tail light. The rear brake operates the brake light too, or its supposed to.
My 99 lost the front brake stop light activation. A spritz with a clean lube brought everything back to life. The switch can be accessed to do this.
i had the same issue with my 96. just pulled the wire and reconnected it problem fixed. on your bad one did it click when activated?
The Honda tech tested it and said it was bad :smile:
lol cheater
cheater naw i dont blame you if its warranty work why pull your hair out let the mechanic pull his out
End of thread · 6 posts recovered Wayback Machine snapshot 19 Oct 2011
