Just wanted to thank Tightwad and everyone else for their help in getting me the information I needed to fix my electrical issues.
Symptoms on my 06:
Dead Battery
Low Voltage with new battery
30 amp fuse browning and smelly not good
Not able to maintain a good charge
HID headlights - low beams worked - high beams shut off a low beam (ballast closed due to inadequate voltage)
Resolution:
VFRness installed with Accessory Fuse box
Rewired grips and seat through accessory fuse box (dealer ran them all over the place)
Results:
So far it's perfect!! 12.6 cold crank, 13.5 at idle, 14.5-14.7 at 5,000 RPM and with brights on
I'd highly reccomend the ness to anyone having trouble. Josh has been more than helpful and gone above and beyond. The craftsmanship of the VFRness is above any high expectations I had (based on everyones praise prior to me). He has been more than responsive and I really appreciate his help getting me back up and running!
Project continues:
Now that I'm a basic VFR electrician I'm still going to continue rewiring and beefing up my stock setup. I think I'm going to run my HID lowbeams through my highbeam wiring harness. Run the High beams to the fusebox and relay with an added switch. I could fix with Josh's voltage latch, but I think I am going to give this a whirl. This would allow me to start the bike with no lights and then switch on my low beams using the high beam switch.
I still need to complete trouble shooting my hot grips. I think I may have a short in the wires somewhere but won't know until I complete the install on the fuse box.
Thanks again to everyone. I feel much better knowing I'm not riding on a 30amp frying pan!
Symptoms on my 06:
Dead Battery
Resolution:
Results:
Project continues:
