13712km and my bike goes into limp mode.
History:
Have had one or two glitches in the time I have owned this bike.....some surprises but generally all has been OK. Heard of the possibility of getting the new maps on my ECM so I took it out, sent it to the UK and had the new maps installed. That was about 500km ago.
Rode out this morning. A short trip of about 10 km to our Rider Training facility and parked the bike. 5 hours later, start her up, select "D" and ride off. notice that the bike is not changing gears!!!! Looked down and saw a flashing "-" where the gear indicator should be. Alarmed, i came to a stop at the earliest possible time. Heard the gears clank but the flashing "-" continued. Strange. Cycled the ignition and all appeared to be back to normal. So engage "D" and ride off again......no joy. As soon as I go over 10km/hr, bike goes into the limp mode again. Come to a stop, hear the clanking again and I realize the bike has selected 2nd gear. And this is the gear that takes you home. Limped back home and pulled out my manual!
Got the DTC fault codes, Faults in the ABS system (front wheel speed sensor related), Faults in the EFI system (Front Wheel Speed Sensor related) and faults in the DCT.
Cleaned both wheel speed sensors and cleared all the faults. DCT faults came back and bike still goes to limp mode every time i go above 10km/hr.
Service manual has the fault down to "Inner mainshaft / contershaft speed ratio failure".
I am tired!!! :sad: I didnt get a bike so as to have to fix it!!!!
But what to do...
There are 4 reasons for this fault
1. Rear Wheel Speed Sensor Malfunction. Took out the sensor and cleaner it out. Checked the sensor as described in the service manual.....It is OK
go to 2
2. ABS Modulator or its circuit malfuncton. Ran the check on this and all came back OK
go to 3
3. Inner mainshaft sensor or its circuit malfunction. Have run out of time....will start this on Monday and see what happens.
By the way, reason 4 is faulty ECU :sad:
Has anyone had the DCT throw a fault??
History:
But what to do...
go to 2
go to 3
