929 shock - turning bottom mount 90 degrees - Suspension
5 posts Started 23 Feb 2012 Last recovered post 1 Apr 2012 Wayback Machine snapshot 18 Jun 2012
Can I turn the bottom mount on a 929 shock 90 degrees without screwing up the internal valving or adjustments?
   Jeff
Yes. You can rotate it by any angle.
+1
How does the bottom adjuster work to vary the damping? Also where would a good place be to start regarding settings?
Turns out from closed?
Thanks,
   Jeff
There is a rod that goes up the center of the piston shaft to the valving piston inside. The end of the rod is tapered to make a needle/seat arrangement.
Settings...... on a stock shock I'd start at 2 turns out and adjust from there. Feel free to play around to find something you like.
End of thread · 5 posts recovered Wayback Machine snapshot 18 Jun 2012
