Throttle control
- [image: Attached Image: IMG_0140.JPG]
It is nice, and the weight can help (if only a little) with vibration in the throttle grip. ...that said, I had a Kaoko Throttle Lock on my KTM 950 Adventure, and it worked every bit as well as a throttle lock (actually, a bit easier to operate). My biggest complaint with the bar-end type is that they are a bit of an art to actually use.
I also started using a Throttle Rocker (one of those palm-rest things) and it also helps on longer rides. I'm a very "loose fingers" type of rider; in fact, my fingers are rarely touching the grips at all on the fwy, yet my right hand will go numb quickly at fwy cruising speeds ...never an issue when sport-riding; so the Throttlemeister comes in very handy on longer rides!
Highly recommeded, (I dont know how I did long trips without them)
[image: View Post]dcassidy1214, on 12 March 2012 - 11:49 PM, said:
My 6th gen came with a Throttlemeister and I will never part with it! Didn't use for a while because it made me nervous living in the city and all the traffic. But once I used it, It's hard to keep my right hand from frequently fondling it on the highways.Uh...what are you fondling?
Throttlemeister here...no fondling...
I know this is an old topic but has anyone tried the Omni-Cruise on a 7th generation? We are looking at doing a 2-up trip across the country in July and just looking at an option to rest the throttle hand once and a while.
That's what I have on mine. I first bought a Go Cruise, which is a copy of the Omni Cruise. Like it so much I bought the original. Each one has some pros and cons. The Omni Cruise has a large thumb assist, and it is a bit more refined, but I like that I can adjust Go Cruise's tension wheel with my index finger without lifting off my throttle grip.
You are right about these being nothing more than temporary throttle locks... not cruise control. As long as that is your expectation, either will serve the purpose very well.
Decided to make a clone Vista Cruise for limited space reasons also, of course made of stainless steel to get the same corrosion résistance as the original plastic version
- [image: img20141206_180525resized.jpg]
Just to throw a little variety into the mix, I've got the BrakeAway cruise control. I had the Throttlemeister on my last bike and I wanted something I could toggle 'on/off' faster and easier.
[image: IMG_20130723_220003_zps7afb7067.jpg]
[image: IMG_20130723_215930_zpsd6e710c5.jpg]
looks great, which version did you install? the VFR1200 isn't listed on their site, how was the installation?
I installed the BrakeAway unit for the Suzuki Bandit. I believe it's the older 6CP02-03 unit... not the newer one.
It's not quite a bolt up solution as the bracket is a little short.
[image: IMG_20130723_220020_zps1020b595.jpg]
My BrakeAway Cruise Control on my V-Star was my favorite solution... in a pinch, the cramp buster worked GREAT on my 600+ mile ride back from TMAC
I fitted one of the new model Breakaway Cruise Control. Model 7CP02.
I do have LSL handlebars, but it should still fit the standard bars.
It fits 7/8" bars.
Unfortunately not compatible with heated grips these latest solutions, besides the fact that they are reasonable gripspace consuming
That's nice. If you happen to be interested in making another one and selling it please let me know.
I ended up going for the kaoko cruise control for my upcoming trip and initial impressions are very positive.
I like to ride with my palms extending past the grips and onto the bar-end weights. I'm afraid that I would inadvertently engage the Kaoko and Throttlemeister units.
The brand-new Atlas looks ideal, but how did they come up with that price??? http://www.atlasthrottlelock.com/order-atlas/atlas-throttle-lock
Has anyone tried the one yet?
I per-ordered the Atlas back in January with high hopes it would work on the VFR1200. I posted my thoughts in the vendor's thread on advrider. http://www.advrider....=1014518&page=9
Long story short, it doesn't work on the VFR. It's a well made piece though. I'll probably stick it on my WR250R.
Thanks for the tip, Swimmer. I hate having to return merchandise.
Sent from my OnePlus One using Forum Fiend
He's right ^^^ ....
Roll On ..
@Swimmer, if you didn't have heated grips would you have been able to get that throttle lock to work? I think it looks way better than my brakeaway lock and the push button operation is really all I need.
Without the heated grips I'd still have the problem of the lock hitting the brake when I wound up the throttle but, like I said in the post I run the brake close to the grip. Position 6.
The there is the issue of the little rubber pad not having much surface area of the throttle housing to grip against. Seems like this would be a deal breaker for any VFR1200. The VFR does seem to have a stiffer than normal throttle return spring though, IMO.
Also the lock will hit the tank fairing at near right lock.
I put the lock on my WR250R. Works fine on that.
Maybe I'm just confused on how something like this is supposed to install. I guess I thought that it attached to the throttle housing somehow so that the unit didn't rotate. If that was the case, then you shouldn't have to worry about it hitting the brake or rotating its way into interference with other parts. The way your pictures make it look, the ATLAS moves around all willy nilly until you lock the unit and then just uses friction against the throttle housing to keep the throttle from rotating... I fired off an email to them to see if they can provide some clarifications.
I do like my BrakeAway unit and I think it works nice, but I just don't care for the look. If I could get something like the ATLAS to work, then sell my BrakeAway for what I have into the ATLAS, I would be happy.
Edit: I completely misunderstood how the ATLAS worked. I thought it attached to the throttle housing and clamped down on the throttle tube when the button was pressed. Instead, it rotates with the throttle tube and applies pressure (with 'friction pad') to the throttle housing when the button is pressed. Completely backwards from what I envisioned and probably not what I was looking for.
Carry on.
