85 VF1000R Shock mount
6 posts Started 22 Mar 2012 Last recovered post 28 Mar 2012 Wayback Machine snapshot 24 May 2012
Is there anyone with an 85 VF1000R than can give me their inside measurement between the top shock mount? I went to install my Hagon today and the center bushing is off 3mm. Between the mount is 40mm on my bike cut and dried I have measured it 20 times. The Hagon shock bushing is 43mm and is not even close to going in. My only choice is to have the bushing reduced but I am not understanding why both the JD and now the Hagon were off by 3mm on the top mount? If I remove the bushing it slides in perfectly so the shock will fit if the bushing is reduced....puzzled?
Something interesting for you. I measured a bare 1985 VF1000R frame and it's 40mm. I measured a bare 1984 VF1000F frame also and it's...44mm.
EDIT: I have double checked my measurements for the stock VF1000F frame. The opening for the top shock mount and the upper shock bushing are both 44mm. The point is that the F frame and bushing are the same measurement.
[image: View Post]VF1000RS, on 21 March 2012 - 11:01 PM, said:
Something interesting for you. I measured a bare 1985 VF1000R frame and it's 40mm. I measured a bare 1984 VF1000F frame also and it's...43mm.
Thank you, I have been wondering this entire time if the R and the F were the same. This is good info..
I had the same problem, hagons listings were wrong - they did me a smoking deal on correct shock. The later  model 1000F and the 85/86 1000R had the 40mm top mount the 84 1000R had a 44mm mount. I think I have that the right way round. Will have to double check when home.
Hagon is sending me a second shock, should be here this week.
Forks back together with a little help from Rich at Sonic Springs.. :fing02:
End of thread · 6 posts recovered Wayback Machine snapshot 24 May 2012
