Easy one...clutch oil filter change.
5 posts Started 22 Mar 2012 Last recovered post 23 Mar 2012 Wayback Machine snapshot 22 Apr 2026
Sorry to bother everyone with a simple question, but I've searched the site and the web to no avail. What's the torque spec for the bolts that hold on the clutch oil filter cover on the DCT? I have the service manual for the standard clutch and it doesn't say. Thanks.
I've got the page open in front of me now and it just says 'tighten the bolts securely'.
The torque values section doesn't give a specific torque but the ibf-ft for 6mm flange bolt (8mm head, small flange) is 7, large flange 9.
6mm flange bolt (10mm head) is 9.
If you need more help please shout :)
Peter
Dutchgixxer
6 Nm
Dutch is correct....6Nm it is. These are only small 6mm x 1mm pitch bolts in aluminium.
Cheers,
Smithy.
Thanks everyone. Change went off without a hitch.
End of thread · 5 posts recovered Wayback Machine snapshot 22 Apr 2026
