I spent a good 6 hours total time over 3 days figuring out how to bleed the LBS (linked braking system) with ABS on my '06.
Unfortunately, there's hardly ANY concrete steps on what the correct method is, without using a vacuum tool. I've searched on VFRD, VRFWorld and though everyone talks about the correct procedure, there aren't any tutorials or pictures beside's HS's thread which is not as thorough as some would like.
My bike is currently completely apart, and I personally love creating DIY tutorials (here's a few on a Subaru board I used to frequent, JDM Projector Install, Timing Belt And Waterpump, HID Projector Retrofit)
Now my question is for the brake bleeding gurus out there. This is what I've come to understand from my experimenting from reading threads and the FSM using Speed Bleeders. I haven't put my bike together, but I'm confident that there's no air in the system. I would like you masters to just go over this procedure and let me know if there's any oddities in my method. I haven't tested it out yet, as my bike is apart and I'd like to take pictures to make a DIY guide for those that come after us that will be very thorough and complete with loads of pictures!
1. Left caliper, upper/outer bleed screw: using the front brake lever.
2. Right caliper, single bleed screw: using the front brake lever.
3. Proportional Control Valve (PCV), battery side: disconnect the left caliper, tilt caliper 15° from ground line, manually pump secondary master cylinder (SMC).
Now, this is where my first problem started. At first, there was pressure and fluid would come out, but after a while, no fluid anymore. The FSM says to fill the master cylinder reservoir when the fluid level drops; I assumed the front lever one. However, while manually operating the secondary master cylinder on the caliper, the fluid would come out from the rear master cylinder reservoir. After a few manual pumps, no fluid was coming out. This makes sense because that SMC doesn't have a reservoir hooked up to it and it can't possibly push fluid out. So what I did to compensate was, operate the rear pedal lever (foot one), that got the fluid moving and then I'd go back and operate the SMC. When no fluid was coming out again, I'd go back to the rear pedal lever, prime it again, then go back to the SMC.
I went from regular DOT4 fluid, to ATE SuperBlue so I could see when the new fluid was coming out. Once new fluid started coming out from the SMC, I primed it once again with the rear pedal lever then did one final bleed and tightened up the PCV bleeder.
Edit: After reading this thread, it looks like I should have used the front lever instead of the rear pedal lever to maintain pressure. The only problem I see with that is, you'd have to mount the caliper temporarily so you don't squeeze your pads. Please confirm!
4. Rear caliper, inner/centre bleed screw: using the front brake lever. Mount caliper at 10 o'clock position.
I think I messed up and used the rear pedal lever for this. I must go back and re-bleed.
5. Proportional Control Valve, opposite battery side: using the rear pedal lever.
6. Rear caliper, upper/outer bleed screw: using the rear pedal lever. Mount caliper at 10 o'clock position.
7. Left caliper, inner/centre bleed screw: using the rear pedal lever.
If this is the correct procedure, please let me know or if there's a sequence error, please correct me so I can do it right and then create a very thorough LBS brake bleeding guide for all to enjoy!
Thanks for reading!
Thanks for reading!
