Ref; 86 VF500F
Hey all,
I just picked up a 1986 VF500F that is complete and everything is there. It had been sitting for a couple of years. After some quick rework on the carbs I got it to fire and run but it sounded like it was only running on three cylinders. Checked compression and #1 was down. I took the valve cover off only to dicover a broken exhaust valve. The tip of the valve shaft is gone but I can see the the broken top of the valve just below the retainer so I'm hoping it hasn't hammered the piston or tore up the cylinder bore. I haven't had the time yet to pull the engine for further inspection. I know the 86 has the smaller carbs on it. Is there also a difference in the valve train sizing as well? The parts fische lists a different part number for the valves from 86 as opposed to 83 - 85. There's a couple of OEM valves listed on eBay from 85's fairly cheap. I'm hoping the bore isn't trashed. It would be a shame to have to part this bike.
Here's a shot of what I saw when I pulled the cover...
Hey all,
- [image: Broken Valve.JPG]
- [image: Broken Valve 2.JPG]
