I mentioned last year that I picked up a couple of sets of the Bridgestone BT-016s from Chaparral for the delivered-to-my-door price of around $180. I also mentioned last year (about 50 times) that I relocated to East TN from Central Florida. I was warned by those that know (BR) that tires wear a little differently in the mountains of TN, GA, NC than good old CFL. Sage wisdom. 1,733 miles and the 016 front is toast while the rear probably has 500 miles or so but it has cupped so much I will keep it for a get home tire for my FL buds.
The 016s replaced my 023s that I tested and they were an immediate improvement in grip and nuetrality though the 023s were decent and either tire will allow you to enjoy twisties with minimal drama, just a mph or 2 below what a better sport tire will allow. I put the 16s on late last year so they stayed on the bike through the winter and were used in a lot of cool weather riding which may explain part of their short life.
The 016s got hard as a rock at the end of their life so i suspect they did not like repetitive heat cycles and then sitting for the winter. They were fine last year and I have another set ready to go so I will save them for warmer weather to see if the mileage improves. I don't mind 1,700 from a tire if all the miles are quality and the tire remains consistent. The 016s were decent but not at the level of the competitors. I will not be buying anymore but anyone on a first cost budget could do a lot worse.
KEB
Pics, front on top and rear on the bottom.
KEB
- [image: IMAG0733.jpg]
- [image: IMAG0735.jpg]
