Failed Alternator stator, 2010 Model
6 posts Started 12 Apr 2012 Last recovered post 13 Apr 2012 Wayback Machine snapshot 18 Jun 2012
Well it happened to me, So now I suppose I can step up my VFR involvement another notch.
I thought I would write out the sequence of events in case any one else sees a similar pattern. Fore warned, is fore Armed.
It all started on the day of the 48,000 Km service on Tuesday, April 3. Which just so happens to be at the place where I purchased the bike new, Just under 2 years ago (19 April 2010 to be exact).
After the service I went to ride the bike away, but noticed the "F1" light was on. The service guy took a look at it then stopped it and started it a couple of times and then took it into the workshop for about 15 minutes. He came back and said that it went away, but the diagnostics did not reveal anything. They said bring it back in if it comes on again.
On the ride home I got caught up in the peak hour traffic and crawled along for maybe 30 minutes of stop-Start. Noticed that the temperature was climbing,   saw it up to 112C. In order to give it some relief, I turned the engine off at the next red traffic light.
When I started the bike again, I noticed that the headlights did not come back on again initially, ( I have Tightwads HID Kit so the battery voltage must get above about 13 volts before they will strike.) They did strike and come on once I started moving with a bit of speed, but by now my attention was well and truly focused. My volt meter was only reading around 10 volts with the machine at idle.
Back at home I rounded up my multimeter and removed the seat so that I could measure the voltage directly at the battery terminals and avoid voltage drop errors.
The bike had cooled and when I started it,  The voltage easily went up to 14.2 volts at around 5,000 RPM.
To me this looked ok, and the headlights come on with no problems.
On Wednesday I did a quick run down the gold coast and back, at highway speeds, no peak hour traffic, but my fixed voltmeter went up to about 13.5 volts.  My thinking was that there would be maybe 0.5 volts drop along that wire, So it would be about 14 volts on the battery would mean that the operation would not drain the battery, but On the same token, It would not give the battery any appreciable charge either.
I had no repeat of the earlier mentioned low beam lights not coming on.
Thursday I had to go down the Gold Coast again, (about 50 km each way) and as this was the thursday before Easter, you can imagine how the traffic was when I got back to Brisbane. This time I crawled along, stop start for a much longer time, say about 60 minutes. Complacency had gotten to me, so I did not actually see what the volt meter was doing.  I stopped at the post office to collect the mail, and when I came out, The bike would not go at all.   All the display lights came on, and no F1,   The fuel pump pressurised, but when I hit the starter,   NOTHING.
NOW I KNEW I HAD A PROBLEM.
I Managed to get the bike going by clutch starting it down the driveway at the post office, and luckily home was little more then 500 meters away so I made it there with no further problems.
Over the Easter long weekend I did a few runs and never saw a repeat of the problem, although my little fixed volt meter never showed the voltage getting above 13.8 or 13.9 Volts.
On Easter Monday I stripped of all the plastic, and did a very close inspection of all the plugs associated with the R/R and the alternator, No sign of any discolouration and no bad plug connections.  All looked good.   I checked the wiring associated with my various electrical modifications to make sure nothing had come astray during the service, (48,000 Km is a VTEC Valve clearance check so they would likely have stripped away a lot of stuff to allow them to do it). All looked correct and serviceable.
First thing Tuesday (After the Easter break) morning I contacted the Bike shop and they said bring it down. I did.
They inspected it and told me that one phase of the alternator was shot, and started to quote my pricing for a new alternator. I stopped him mid sentence and commented that it should be still in the 2 year warranty period. He checked and said that it still was, (for at least another week or so anyway). Arrangements were made with Honda for a replacement alternator stator, and a battery as well.
His opinion ( and it makes sense to me too)  is that the high engine temperature either initially caused the alternator winding failure, or just made it deteriorate that much faster.
I am away on the other side of the country at the moment, and I will go straight the US once I get back home, so I arranged with them to keep my bike for the two or so weeks, and they will install the new stuff when it comes in.
I have to say that the guys at the Honda dealership, were very supportive, and have told me they will deliver the bike back home (35 km away) when the work is completed.
I suppose the moral of the story is that as soon as you notice a change in the way the charging system operates, It is time to get it all looked at by someone that knows about it.
Tom
Well, if ya gotta break down, 2 weeks from warranty expiration is a good a place as any to do it!
Make sure they test the R/R as well!
Let us know how you get on!
Let me get this straight:
When you dropped off your motorcycle for service there was nothing wrong w/it-at least as far as you knew. Then when came to pick it up AFTER they had worked on it the FI light came on as soon as you started it?
Shop mechanic looks at it for 15 minutes, gets the light to go out and says nothing showed up as wrong per the diagnostics. However, before you can ride home the bike starts acting up by showing signs of low voltage?.
Warranty or not, I'd hold the shop accountable before I'd pay them anything for the repair if I were you. Could have just been a coincidence-but perhaps not. If they plugged in something wrong, shorted a wire, etc. while working on it they could have caused the stator failure., If so it's doubtful if the mechanic would own up even if he knew he'd made a mistake.
Hopefully the warranty will cover everything,you'll be good to go and won't be charged for any of the repair. If not I'd make a major issue w/the service manage over the fact that FI light wasn't on when you dropped it off, and was on as soon as you started your bike after they had worked on it.
I wonder if it was more a factor of the bike not charging at idle and spending so much time at stop and go speeds...battery drained and then the charging system overworked to keep up?  I guess if a stator phase burned that wouldn't be it however.
SMothsailing, ,
Yes, Do not worry, My first thoughts were that they had put something back together wrong as well. That is why I pulled the plastic off to check EVERYTHING. Just so I was in a position of knowing where it stood before I put the situation to them. It all looked good. (I fix broken electrical equipment for a living so I know what bad looks like).
With regards to the "F1" light. This has come on a couple of times about a year ago and then went away again ,but it had no noticeable effect on the bike. So It's appearance and disappearance did not fluster me too greatly, but I was concerned that it was on just after the service.
Guess time will tell.
Gday Tom, hope you get it sorted... just today I soldered the 3 yellow stator wires up. Connector decided to take a dump on me.
I was curious which Honda dealer you sort? Probably time I too did a valve clearance.
End of thread · 6 posts recovered Wayback Machine snapshot 18 Jun 2012
