Ok, bear with me on this one.
Just got a used ohlins for my 5th gen, spring rate is 16.3kg. It has the groovy hydraulic preload adjuster on it but you can also set a non hydraulic, "regular" preload ring while the shock is out of the bike. I've searched here and google for a chart or something to get me in the ballpark on that adjustment before I get this thing all fitted up and back on the road. Any help here or do I just sort of go for it and start fiddling? I'm about 155 WITH my gear on if that helps. Suspension is otherwise stock, pending fork internals swap.
Thanks for any help you can render.
