This is probably already widely known but for those who've not learned this trick...
When changing plugs on these Hondas with deeply recessed plugs and aluminum heads...getting the plug threads started properly can sometimes be a dicey operation. Many times you might have a couple of extensions and a universal between you and the plug, making it really difficult to feel and to know that you have the threads started correctly. Cross-threading a plug can be an expen$ive mistake..
A good way to start the plug and to give yourself some "feel" as you do is to use a short (3-4"?) section of air tool hose or even fuel line. The plug ceramic end is pushed into the hose, which acts as a 'handle' for the plug now. You can bend the hose to insert the plug down the passage to the head, then 'twirl' the hose between two fingers, feeling how the plug threads are engaging. The rubber of the hose makes twisting it easy, but if you get the threads started wrong, the hose will spin on the plug ceramic before you tear up the threads, and you can back off and re-start the plug properly...Once you get the plug's threads engaged correctly and you run it down as far as you can, then the air line (hose) just pulls out of the plug well and you can torque the plug down with your wrench...
Hope some find this useful
Don Hanson
Don Hanson
