I'm having trouble with my bike blowing turn signal fuses. I replaced the fuse last week and they worked fine, until the next morning when I was headed to work when they stopped working again.
This weekend, I tore all the fairings off and removed the headlight/upper cowl assembly. I can't find any shorts or damaged connectors. The turn signals work fine now that the fuse is replaced. I tried bumping and pushing all the parts of the wiring harness that I could, but couldn't get the fuse to blow again. Did the same with the bike running, no change.
EDIT: Fixed the brake light issue.
If anyone has any ideas, I'd really appreciate it.
