ABM Multiclip - Seventh Generation VFR's
5 posts Started 2 May 2012 Last recovered post 18 May 2012 Wayback Machine snapshot 24 May 2012
I've never seen that before... but that looks really damn slick...  Curious to see what people say. :comp13:
I havent had any experience with these particular ones but I have used adjustables similar to it on all my bikes including my 1200.
JMHO but as risers I dont think 70mm will be much higher than the OEM ones. That is assuming that it is a 70mm rise from standard clip on height. The stockers are somewhere between 2.5 to 3" above a standard clip height to start with.
If you are looking for just a 3" riser then you might want to also check out the Apex bars http://www.apexmfg.c...x-riser-clip-on. They are a really nice bar for 219.00. But if you are going up from stock height then I dont think 3" will help much.
The cats meow for adjustability are the convertibars by far IMHO http://www.convertibars.com/. Those things will go up like 8" if you want to go that high. I think they were around 260.00
Apex
convertibars
Keep in mind I use mine to get the bars lower than stock. But it gives an idea how they look on the bike. The german ones look quality but for 319eu msrp I just think there are better options out there. Once again JMHO.
Edited by tin, 02 May 2012 - 07:03 PM.
Thanks for the infor provided ..
Appreciated ..
End of thread · 5 posts recovered Wayback Machine snapshot 24 May 2012
