Hello, new to forum, posted a couple pics in the intro section.
My girlfriends "02 VFR is experiencing wacky behavior, it has 56K on it. Lately it started draining the battery very quickly when starting, just a few turns and nothing but the clicky clicky from the starter relay switch. The bike would start with a jump. I replaced the battery (free swap from dealer) with the same result. Battery voltage is good (12.4) but with just a few turns it goes back to single or rapid series of clicks from the relay switch. I've pulled the connector and cleaned all connections going in and out. These symptoms happen with bike in neutral or in gear, with or without sidestand up.
Should I put juice directly to the starter and see if it turns over? Can I do this right at the leads coming out of the starter relay? Once the bike is running it runs great. I've got a voltmeter as well, if there's a way to check the relay no problem.
Thanks, Barry
Thanks, Barry
