Strapping stuff down
25 posts Started 22 May 2012 Last recovered post 24 Jul 2012 Wayback Machine snapshot 27 Jul 2012
So Im taking a trip next month and doing some moto camping for about 3 weeks. Im new at this whole thing and literally have no idea how to strap everything down. :huh: I did a quick search and didnt come up with much.
I have the OEM hardbags for my 6th gen. as well as a Cortech sports tailbag (which I also havent figured out how to strap down.) Ill have a tent, sleeping bag, foam pad, and all that good stuff. I think I am going to stuff it all in a drybag so it will all be together.
my main question is what straps do you use, and how do you strap everything down to the tail?
One thing you need is a sidestand disc to rest your stand on when on the dirt(or hot pavement).......... and attach a string to it long enough to be seated on the bike, then lift the bike off the stand and pull the disc up and put in tank bag.......
best for me is the cargo net things,  you can link up more than one to extend range of what you need to tie down....
  That's what I use.  See avatar.
GET ROKSTRAPS ™ forget any other kind of straps!! They are the best straps to use on a motorbike,bar none. MCN has always rated them the best. Once you use them you will not use anything else. One bloke used them to tie a water heater to his bike to get it home. Try that with bungee straps. No kidding.[image: nevada and east 001.JPG]
See those blue waterproof duffle bags , each one is FIRMLY held down by two rokstraps.
I use a combination of bungees, nets and straps from REI.  Some sort of waterproof stuff sack or bag works well too.
One word of caution is that if you use a regular long narrow tent bag, make sure your poles can't slide out of the middle along the way. I know some one (no not me) that arrived at his destination with a tent minus his poles!
+1 for cargo net, cheap and easy, but I do like the looks of the ROK Straps.
awesome. thanks for the tips! I have one more question though.
Where do you guys actually connect either like the straps or the cargo net. like what do you hook it to. I havent actually tried for myself yet, but just looking around I didnt see much to hook it to.
I use a dry bag, Ortlieb, for all the camping gear and got some Aerostich straps to hold it on. Worked very well on a few trips. Added the cargo net just for anything I might need to add along the way.
BTW, 3 week moto camping trip, very jealous. I've got the itch to go soon. Also check out motocampers.com for more ideas.
Where ever you can , it ain't no piano.
Eight or nine years ago I bought several items of soft luggage from RevPack in California and half a dozen of their two-part quick release straps.  I found the straps to be a huge improvement on bungees, nets, rope and various other means I had used previously.  One caution though: for several years I used the straps to lash stuff down to my DR 650. It's a dual sport that gets ridden off-road, in dirt and mud, so it has its share of scratches and dings.  The first time I strapped my gear down to the VFR I didn't give much thought to the plastic buckles on the straps rubbing against the rear bodywork.  I ended up with a very slight rub mark, likely caused by road grime getting between the buckle and the tupperware.  The solution is to test fit everything at home and put a 1- to 2-inch square piece of clear film under the buckle.  The quick release straps aren't stretchy like ROK straps, so I find that I cinch things down when I take off, then at the first gas stop, tighten things up again and I'm set.  The nice thing about the quick-release buckles is that you don't have to adjust again if you just need to get into the bags.  You pop open the buckles, access the bags, and clip the buckles again when finished.  Of course, if you substantially change the load (like add or remove a jacket from a soft bag) you will have to cinch the straps again, though that only takes a few seconds.
Strapes  if you're concerned about the back panels..........
[image: index.php?app=gallery&module=images&section=img_ctrl&img=399] DSC00172.JPG Album: "Presious" Uploaded 06 Jul 2009 - 14:30
Rear pegs or rear grab handles if feasible. I use a cargo net over my backpack so I don't have to wear it on my way into work.  I personally don't have side bags
I don't usually strap stuff to the VFR - just use two zip-together Ventura packs and an expandable tankbag. On previous bikes without a rack, I used to bungee stuff onto the pillion seat, and it was forever wriggling around.
On a cautionary note, I used to have a friend who lived about a kilometre from me who had a lovely Anniversary Edition VFR (the 5th Gen one, not the 6th Gen).  Apparently, the police reckoned his luggage came loose and flipped sideways into his back wheel at an estimated 100-120km/h (he woke up in hospital remembering nothing of it). His bike was pretty well trashed, and he spent months in rehabilitation. When I last spoke to him, he'd had to give up motorcycling and cycling.
Rok Straps. Only thing I use. I threw away the cheap bungee net and gave my old bungee chords to a friend. Rok straps don't have metal hooks to bend or worse yet scratch your bike. Never had one come loose and I think you could probably lift the bike off the ground if you hooked a couple of the Rok Straps to a hoist, they are strong.
Many camping trips under my belt with my sleeping pad, tent poles, and a few other things in a dry bag straped down with two Rok Straps. Tent, stove, clothes, and personal items in one side case. Sleeping bag and small items in the other side case. Small cooler, tool kit, hat, spare gloves, jacket liner, and rain gear in the top case.
I have a set of Roks now, but when I did my epic ride, I strapped my duffel to the seat using four bungies:  two diagonally across the centre of the bag, and one each side going front to back.  These were hooked to the grab rails at the back and the frames for my Givis at the front.  I still back up the Roks with a couple of bungies.
Edit:  Leave a couple of minutes the first time to put some tape on the body panels wherever the straps or bungies contact it.
Glenn
There are plenty of places to strap a cargo net to.  Grab handles, mounting hardware for your hardbags, footpegs, etc.  If you don't see any place for it, you aren't looking.
But I don't understand where you're strapping stuff to if you already have a tailbag.  If it's a motorcycle specific tailbag it will already have it's own mounting system and it will occupy your tail section...
Its a tailbag with bungie hooks for mounting. I hooked the front hooks to the passenger pegs but there was nowhere very secure to attach the rear hooks. I think possibly with the luggage brackets on I might have somewhere to mount them, but at the moment there isnt much to attach them too.
I have the Touratech tailbag with built in bungee straps. They do the job of keeping the bag on the bike but without a cargo net or bungees over it, the bag tends to slide forward on the pillion seat into the rider seat area. A couple bungees/straps or cargo net keeps it out of my way.
Here is a pic of my solution: a REAL frankenbolt. It is an old through-engine bolt that Radar's Sliders Kit replaced. (The black shock cord is to keep the frankenbolt from rattling - it could be more elegantly installed)
  • [image: frankenbolt 001.JPG]
I like the adjustable bungees, the nonadjustable stretch and never seem to be the right length.
The straps look like they would even be better.
I hate the bungee net, probably because I lost a tent one time and jacket another.
They're tooooo stretchy. :pissed:
Unfortunately, this is not an isolated occurrence.  I have seen rear-seat loads jammed in rear wheels and have heard several stories--some ending in death.  Be very careful about strapping loads to the bike where you can't see it...
So what size or length of rok straps are you guys using?
End of thread · 25 posts recovered Wayback Machine snapshot 27 Jul 2012
