The upper hose on the RH radiator (the one that connects up by the spout where the rad cap goes)......... what is the thingamajig the other end connects to, and is it normal for it to be loose/wobbly?
I ask because I had a bit of a scare today. I rode the bike to work (about 5 minutes, maybe) and got a couple tiny drops of what I initially believed to be coolant dripping off the lowest portions of the fairings. Additionally, there was a bit of steam coming out from the RH fairing up near the top. This is after a pretty spirited ride to work where I was intentionally trying to put the cooling system through its paces to shake down the work I had done as described in this thread:
http://www.vfrdiscus...e-running-temp/
I let it idle in the lot and didn't get any more drips. When I got it home, same thing. I tore off the RH fairing and couldn't find a single drop, even after letting it idle half an hour in the garage. I shook every coolant hose I could, pinched 'em all, etc, and couldn't get a thing. And, FWIW, I checked the coolant level under the cap and it was to the brim like I had left it.
As to what caused the coolant drips this morning, I have a theory. While doing all the coolant work, I was pretty sloppy with letting the rad overflow while burping the system, leading to a lot of coolant residue all down the RH side of the bike (along the frame, off the hoses, etc.). I had ridden it a couple of times since doing the work with no issues, but this morning there was a VERY dense and thick fog. My guess is that the drips were actually just condensation/moisture dripping off the fairings, but combined with the coolant residue to give it the sweet smell I noticed when I checked out the drops. It'd make sense, especially since the drips on the fairings were not blue in color like they should be (the current coolant is Engine Ice).
Sorry for the long post, but I'm trying to work out everything before the next track day on Monday.
Mike
Mike
