98' stock mirror question? - Fifth Generation VFR's
16 posts Started 15 Jun 2012 Last recovered post 17 Jun 2012 Wayback Machine snapshot 1 Jul 2012
Finally after 3 years was able to take the VFR out on the road to get a state inspection yesterday. It was an 80 mile round trip! I forgot what an amazing MC this is!
This bike sat in storage for over 3 years with just sta-bil in the gas. It never was suppose to, but I had back problems and couldn't ride, or touch the bike until last week. Put a new battery in, it started up after a min or 2, and runs like I rode it the day berfore!
Anyway, the problem I have is with the mirrors since it was new.
No matter how tight I make the bolts under the plastic cover on both mirrors, they come loose at normal highway speeds, getting pushed back towards me. I am forever adjusting with them while ridding.
I had a 91' VFR, that had similar mirrors, that never did this.
It looks like this mirror design was only used on the 98' & 99' model, and a newer design without the plastic cover on the 00' & 01'.
What I would like to know, is anyone with these stock mirrors have the same problems, and maybe Honda changed them on the newer models for this reason. If so, will the 01' mirror fit my bike without and mods?
I also own a '98 w/the stock "condom" mirrors. However, I've only found it necessary to tighten the bolts once since purchasing my viffer last year and haven't experienced the loosening issue you described since. Of course, if the mirrors' positions are changed regularly I can see how re-tightening the bolts might be required on a more frequent basis. Still, during a ride last weekend I topped 100 mph more than once, yet the mirrors never changed position.
Have you considered disassembling the mirrors to make sure there's no grease or oil present that could be contributing to the problem? I guess it's also possible the bolts could have been over-tightened in the past and that the metal may have been fatigued or damaged as a result.
I'm fairly sure there are some relatively inexpensive aftermarket mirrors available (Emgo?) on ebay and from other sources to replace the stock mirrors. I've also seen stock mirrors advertised for sale in the forum's classified section from time-to-time.
A lot of people don't seem to like the "condom" mirrors, but I had no problem w/them and wonder what's the big deal.
Edited by smoothsailin, 15 June 2012 - 10:04 AM.
My mirrors on my 98 do that (well, the right one...still stock). I replaced the left with an EMGO 2000 model year replacement, and it doesn't have the problem. I cover my bike every day, and the cover moves the mirror at the proximal articulation more and at the distal very slightly (closest to the mirror and farthest from the mirror, respectively). I will get a replacement for the Right one sooner or later, but recently upgraded pegs, windshield, helmet and added a luggage rack. Somehow the $35 seems to get pushed back because the mirror still works fine, it just looks different, and needs to be tightened every few months. So I live with it. I am trying to get some money together to bring the wife into the 90s at least (her ride is an 85 GPz), so...
  One day. Keep tightening, or buy a new one! EVen better, buy the set, and have spares if you need them!!
  Cheers!
Just use some lock tite/thread locker. The blue one.   They won't come loose very easily with that.
Thanks for the suggestions,
I guess that thru the years of constantly tighting the bolts could be part of the problem, I wonder if they could be replaced. I'm the original owner, and the mirrors started doing this on the way home from the dealer! Everytime I went back for service, I would mention this to them, and all they did was tighten up again. I think at this point, they should have replaced them under warranty.
Like I said on my 4th gen bike with basiclly the same mirror, never had this problem.
Thanks for the loctite suggestion, I will try that. The problem is that you have to have the mirrors move some what, when someone walks next to the bike and knocks them out of adjustment.
I would like to keep the oem mirrors if possible, or if someone knows if the 00' or 01' mirrors will fit, I think they look better then the condums anyway :blush:
The 00 01 mirrors fit. I would get the emgo ones from Amazon, they are basically the same.  I think you need to order some rubber part mounting thing for the 00 01 bike to mount them though. Maybe someone can chime in or if you search I bet you can find it.
Yes, you will need the rubber base from the '00 because the footprint is different from the '98.  This is the part you'll need:
71-88113-MBG-D00 : RUBBER, MIRROR BASE
I got mine from powersportsplus.com
You should also get new bolts.  There's a lip on the '00 mirrors that makes the '98 hex head bolts a total b*tch to tighten down.  6x16, which you can pick up at home depot or part number 96600-06016-07 : BOLT, SOCKET (6X16) it seems.
Use allen head bolts on the new mirrors.
Thanks for all the info!
I went onto e-Bay, and looked at the EMGO mirrors, but would prefer getting the OEM ones for the '00, or '01 bike!
So far, I've been to several online Honda dealers sites, but couldn't find a listing/part # or price!
The mean time, I'll try to maybe replace the pivot arm bolts, and try loctite
The Honda ones are pretty spendy. I got emgos and they are nice. You will need the rubber base piece but they are cheap. Both emgos and the bolts and the rubbers are less than one factory mirror. If you are at you local shop, the mirrors are in the Western Power Sports or WPS book
The emgos are cheaper at Amazon.  Unless you have to pay sales tax then it might be the same as a tax free ebay sale.
Check this - #23 & #25
http://www.powerspor...COWL/parts.html
Hey, I've actually got two extra rubber bases for the '00 mirrors just lying around still sealed.  If you want them (or anybody else wants em) just send me a pm and I'll mail them to ya.
I put off for several years fighting the condom mirrors getting loose, etc.
Finally bit the bullet and bought OEM Y2K mirrors.
I should have done it sooner because they are sooooo much better than the old ones.
What mirrors did you use on your'98?
Thanks for the link to the mirrors! The price isn't bad, if that cures my problem.
It did show the pivot bolt that controls the horizontal movement of the mirror where the problem is with mine.
I wonder if I just replace them, will it correct the problem for now?
I went to the '98 upper cowl diagram, and they did show the bolts,but in the listing that # wasn't listed. I'll call them Monday, and see if I can order them first. Maybe get away fixing them cheap :fing02:
End of thread · 16 posts recovered Wayback Machine snapshot 1 Jul 2012
