[image: View Post]JIMLARCH, on 29 June 2012 - 03:45 PM, said:
[image: View Post]KPerham, on 29 June 2012 - 03:22 PM, said:
Maybe not using the dust seals? Don't know, I've never used their wheel bearings.
The center spacer should be just barely touching, so that you can still move it with your finger. Otherwise the center race can be off center and cause failure.
Not sure what you mean when you say 2mm washers. Is that part of the spacer set? Or how you pressed the bearings in? If you put any pressure on the inner racer while installing them, that can damage them. Driver or press should only contact the outer race of the bearing.
I assembled my front end without a wheel while it was out for powder coating. Just to see it, really. The outer spacers should touch the inner races, and the races should touch the center spacer. All without moving the inner races off center. That should all be locked in, allowing only the bearings and outer races to turn.
I did the front wheel bearings on my 4th gen. I found that prior to taking the bearings out that the centre spacer on the wheel was not touching the bearings, but was slightly loose, leaving the bearings to turn without any resistance. And that was how I installed the new bearings, with the centre spacer slightly loose. I have put 1500 miles on the bike since, and the bearings are fine, and the bike handles well. Correct me if I am wrong, but are you saying that when the axle is tightened up that the bearings press onto the centre spacer, and they all turn, because if that is the case, how come I found that the spacer was slightly loose in the wheel?
I should probably bring this up at the R1 forum, I don't have a center spacer, one photo in the R1 service manual shows one and another photo omits it. If this thing requires a center spacer to go in the hub and between the wheel bearings that't probably my problem.
