I just changed my oil and find I added a little too much (I'm guessing approx. 1/4 quart). Yes I have ridden it (approx. 100 miles) so it has fully heated up and circulated. Picture was taken on the center stand.
What's your opinion (don't sweat it, drain some, etc.) I tried shiponing some out but that didn't work.
I don't like to fill over the top line......... If you have a clear tube you can suck it out till it gets close to you then stick you tongue over it and dump the hose, repeat.
I bought one of these from Harbor Freight with a coupon for $3.99. I used it to drain my gas tank when I was working on my Duc. It worked great as a gas siphon pump. Might be worth a try.
[image: View Post]Switchblade, on 31 July 2012 - 05:03 PM, said:
Yeah, most bikes no problem but my 6th gen it will pump it up to the air box.
Mine too!!
I would get a huge puff of smoke on startup. I thought I needed new valve seals. Turns out it was just too much oil.
