I am preparing to install an electronic cruise contol on the Big Viffer. I am taking the bike from New Hampshire to Seattle, Washington and back next month. The cruise will be a life saver on some of the long stretches of slab I'm going to encounter along the way.
I believe this will be the last mod I am going to make to the bike. It is also the most challenging. Hacking into the stock wiring harness makes me a bit nervous. So, I'd appreciate as much insight as I can get before splicing wires.
The cruise control unit is GlobalCruise from Rostra. It is the same unit Polaris supplies from the factory on their Victory products. I'm comforted in the knowledge that a motorcycle manufacturer includes these as standard equipment on their bikes.
Here is the list of connections I need to make. Some are obvious and easy. Others are a bit more cryptic.
A: Black - ground wire (solved)
B: Brown - accessory power (solved)
C: Red - brake positive (connected to brake light +)
D: Violet - brake negative (connected to brake light -)
E: Dark Blue - tachometer (unsolved)
F: Gray - Vehicle Speed Sensor (VSS) (unsolved - front or rear ABS speed sensor?)
G: Light Green - Neutral Safety (NSS) (connected to gear indicator)
H: Orange - Enable Output (ENO) (unsolved)
The ENO is a mystery to me. I'm not sure what it does or if I need it. "The ENO function allows you to use the GlobalCruise as a driver for an external wheatlamp connected to a V+. THE ENO will drive low when the system is engaged and to a high impedance state otherwise. This wire terminates in the harness." Does this drive the LED that tells me the cruise is engaged?
The items in red are wires I haven't located on the wiring schematic. Any help would be appreciated.
I have attached a PDF of the schematic. Feel free to mark it up.
Thank you very much!
ß!
[image: Attached File] Section 23 - Wiring Diagram.pdf 3.02MB 277 downloads
ß!
